Author Topic: rescuing an old friend  (Read 114814 times)
« Reply #285 on: July 19, 2013, 09:17:14 AM »
there is a ton of room under this thing to get to, and the motor is lifted up an 1" also.  i ran a piece of tube across under the pan with two bends to go down around the pan.  should be cozy to the pinion housing at full driver bump, but fine.  No links or exhaust in the way.  exhaust will be tucked up between the oil pan and flywheel dust shield.
« Reply #286 on: July 19, 2013, 09:49:40 AM »
Trailer dropped.. Box of parts in landing gear of white trailer.....
West hen construction sucks associated.. they are using Inn parking lot as home base....
Srt and trailer driving skills must not come hand in hand.. impressed some yellow shirts.
« Reply #287 on: July 19, 2013, 10:23:15 AM »
What are they doing on W Hen? I haven't been down since it started.
Sofa King tired of construction. My house, work, kims house, apparently M4, between any of the above....
« Reply #288 on: July 19, 2013, 10:38:31 AM »
its weird, they have shut down north bound the last three mornings, but its clear and everything gone when i go home.
think the are just doing shity repairs.
« Reply #289 on: July 19, 2013, 10:44:04 AM »
hmm thought i took a pic of the skid, meh.  all i got.
[attachment deleted by admin]
« Reply #290 on: July 19, 2013, 11:00:12 AM »
Looks like nice piece of pipe there.
I think the exhaust tuck might also fix the cat rattle on the belly skid if not addressed already.
« Reply #291 on: July 19, 2013, 12:52:02 PM »
body mounts on way down to south....
« Reply #292 on: July 19, 2013, 01:02:34 PM »
ohh yeah.. cursed at my landing gear for the last time...
have this coming in from Dayton...
http://www.curtmfg.com/part/28570
this one from Buffalo...
http://www.curtmfg.com/part/28305
2,000lb jack is plenty for my trailer, no?  I mean it’s just for the tongue weight right?  The axles hold the lions share if there is a Jeep on it..
« Reply #293 on: July 19, 2013, 01:15:57 PM »
Ya.  You only need one though ;D
« Reply #294 on: July 19, 2013, 01:16:08 PM »
ya should be fine.  those things seem to all suck.  love whats on goose trailes.  the big trailer even has a gear reduction one.
« Reply #295 on: July 19, 2013, 01:20:56 PM »
my HF unit is working just fine
« Reply #296 on: July 19, 2013, 01:21:30 PM »
well duh one or the other...
rather go with the braket one like I have currently.
« Reply #297 on: July 21, 2013, 08:07:43 PM »
M4 is the shit...
Would fully back him in any automotive business endeavor
« Reply #298 on: July 22, 2013, 08:59:29 AM »
we will get it!
fixed this little issue yesterday.  was sucking my thumb to the manifold in two places.  found howell gasket has 2 cap heads right in the edge of a TBI gaskety surface.  sucked the gasket in.  (red spacer exact print of GM TBI, used for air cleaner height help)
« Reply #299 on: July 22, 2013, 09:00:56 AM »
TBI guru #1, Bret from Semper FI racing stopped over and agreed the leaky aftermarket injector has to go.  the left side pod is just dumping fuel like crazy idle to WOT.
i swapped in some 350 injectors but they are just way too much fuel for this girl.
