Author Topic: 04' 4300  (Read 62264 times)
Re: 04' 4300
« Reply #150 on: December 30, 2013, 11:04:42 PM »
want me to put in a call to regional for you?
Re: 04' 4300
« Reply #151 on: January 16, 2014, 06:02:46 PM »
new surge tank level sensor and ECM reset seems to have cured all problems, probably a dozen cold starts and 6 usage trips with miles since.
Re: 04' 4300
« Reply #152 on: February 17, 2014, 11:01:42 PM »
no start again.
RandR coolant sensor
over fill coolant
pull ecm clean power fuses
clean all battery connections
check both fire wall ground posts (only online suspect noted)- mine are factory seam sealed outside, factory clean and tight inside
no crank
note- intermittent power to gage cluster while cranking- never noticed this before.
go back to shop 2 hours later to drop off something, crank for hell of it, cranks first start.
Re: 04' 4300
« Reply #153 on: February 18, 2014, 12:23:05 AM »
Time for old school no electronics
Re: 04' 4300
« Reply #154 on: February 18, 2014, 07:47:51 AM »
Must be contagious.
Drove the f350 to Binghamton and back saturday. Stopped a few times on the way back. Parked in my driveway overnight. No crank next morning and still as of last night.
Check engine light came on right before we left for Binghamton.
Starter connections look real ugly but too cold to monkey w as of sunday.
First time she has ever left me stranded.
Might be time to get traded in.
Re: 04' 4300
« Reply #155 on: February 18, 2014, 09:13:02 AM »
o mine cranks and cranks like a summer day with 3 batteries.  the ecm just says no thank you with no warning lights whatsoever.
Re: 04' 4300
« Reply #156 on: February 18, 2014, 09:42:31 AM »
wonder if the ECM is saying "no thanks" or if it's something on the lift or injection pump that it's not delivering fuel?
just thinking out loud....
Re: 04' 4300
« Reply #157 on: February 18, 2014, 10:17:34 AM »
No good
Re: 04' 4300
« Reply #158 on: February 18, 2014, 10:18:30 AM »
the two google searches mostly say its a clean power issue to the ECM.  if there was a fuel pressure issue or injection issue it would throw a code and light.    I did check fuel pressure after crank, tons spraying out of lift side shrader though.
when you key on the gages full swing and all lights go on and off.  when you crank, its almost like it tries to do the gage test multiple times, leading me to believe there is loss of power or ground to the dash/ECM
biggest forum solution is take both ground studs apart and clean, check chassis to cab ground, eliminate 2 sets of weather pack connections in the battery box,check battery connections.
Re: 04' 4300
« Reply #159 on: February 18, 2014, 10:52:04 AM »
redoing gauge test definitely sounds like intermittent or dirty power to ECM.
Could it be something at they key, losing power on ign while in crank position? wild hare idea, other connections much more likely
Re: 04' 4300
« Reply #160 on: February 18, 2014, 08:24:23 PM »
fired on first crank tonight
hauled local load like a boss
Re: 04' 4300
« Reply #161 on: February 18, 2014, 10:44:35 PM »
That explains the white truck pulling the black enclosed north on 15 as I was heading south to M4.
Re: 04' 4300
« Reply #162 on: February 18, 2014, 10:46:53 PM »
ya must have just missed you
Re: 04' 4300
« Reply #163 on: March 04, 2014, 10:05:43 PM »
spit and kicked on 2 or 3 for a good 10 seconds and then took off fine today for an hour warm up.
just dont understand this thing starting fine when i dont need it.
Re: 04' 4300
« Reply #164 on: March 12, 2014, 09:44:25 AM »
aw ya lookout
