Author Topic: High Miler  (Read 302560 times)
Re: High Miler
« Reply #450 on: December 18, 2014, 04:46:08 PM »
It's all about the fuel filtration.
I'd suggest preventing this to both you and Ryan. The stock filters just plain aren't good enough. I had drivability issues before I had a water in fuel light. I won't hog it home next time that happens either. Not sure WTF the plan is for that without a drain on the fuel tank...
Less than the cost of one injector, and about an hour to install:
http://www.vulcanperformance.com/VP-MAX-Dual-Remote-Filter-Kit-p/drff.htm
Re: High Miler
« Reply #451 on: December 18, 2014, 04:53:40 PM »
Re: High Miler
« Reply #452 on: December 18, 2014, 05:10:41 PM »
Sounds like snake oil
Re: High Miler
« Reply #453 on: December 18, 2014, 11:44:30 PM »
Smooth install. Runs like a top.
High Miler
« Reply #454 on: December 19, 2014, 11:21:32 PM »
Several hours spent and a dead headlight has resulted in a Lifetime upgrade. Digging it so far! MANY thanks for the help Ryan. Glad I did it there with parts available :)
Both filters taking out some water. Planning to run tanks very low with lots of Howes and draining filters every 150-200mi. Fuel gauge has been fine.
Re: High Miler
« Reply #455 on: December 20, 2014, 01:04:12 AM »
Did you figure out where the water is coming in from yet?
Re: High Miler
« Reply #456 on: December 20, 2014, 03:22:46 AM »
No. Dry forecast...
Re: High Miler
« Reply #457 on: March 16, 2015, 09:03:46 AM »
Checked filters before I went out yesterday since it was finally warm while thinking about it. Very little water in big boy filter, decent amount in stock. wtf?
Aaaand I noticed a miss on my way home. I think it may be time to sell this thing down the river if it really has eaten more injectors. Seriously, wtf?
Re: High Miler
« Reply #458 on: March 16, 2015, 10:36:46 AM »
send it!
Re: High Miler
« Reply #459 on: March 16, 2015, 04:17:30 PM »
Unreal..
Re: High Miler
« Reply #460 on: March 17, 2015, 08:43:50 PM »
What brand the fuel filters you're running? My truck's factory fuel filter is 2 nominal micron if that matter and it certainly have stopped up if I wasnt be careful filtering my wmo.
Find out where water is coming in! I don't have problem with diesel I buy from fastrac and Hess near RIT. Although I run a 12v.
Re: High Miler
« Reply #461 on: March 17, 2015, 10:16:49 PM »
A 12 valve you can dump 5 gallons of water in the tank and the thing will keep running!
Re: High Miler
« Reply #462 on: March 17, 2015, 10:54:01 PM »
Mike, how much you mean by "decent amount" in your factory fuel filter?
I'll bet it'll run ok on a cup of water in the tank, not 5 gallons haha.
P-pump it!
Re: High Miler
« Reply #463 on: March 17, 2015, 11:32:41 PM »
I don't want another project truck. I have enough projects.
Maybe 1/4t in the donaldson(?), and about maybe a bit more than 1t in the factory.
I read of vents on top of the tank on other 3rd gens, need to look.
Wtf though, are the filters there for looks?
Re: High Miler
« Reply #464 on: March 18, 2015, 03:40:08 PM »
Perhaps my panic was premature. It popped a code this afternoon, P0202. Fuel injector 2 circuit/open
hopefully a harness issue; otherwise at least maybe it's only one problem stick and an electrical problem at that.
