Author Topic: D44 or D60?  (Read 20790 times)
Re: D44 or D60?
« Reply #15 on: February 14, 2013, 07:58:58 PM »
It looks to be a 44.
If I can find a set cheap enough I can run them stock and not spend the coin on wheel spaces and Chromo shafts that the toyota axles need.
D44 or D60?
« Reply #16 on: February 14, 2013, 08:13:45 PM »
Your running 2 fronts, you don't need spacers.  In still running stock.
Re: D44 or D60?
« Reply #17 on: February 14, 2013, 08:17:30 PM »
Not 2 front, but still need chromos and larger drive flanges.
A set of tons would be run in stock form, and last fine.
D44 or D60?
« Reply #18 on: February 14, 2013, 09:09:00 PM »
Shit you'll sell or trade it before you can break a stock toy shaft ;)
Your running a rear now?  That will be an interesting drive shaft no?
Re: D44 or D60?
« Reply #19 on: February 14, 2013, 09:16:48 PM »
Front engine.
D44 or D60?
« Reply #20 on: February 14, 2013, 09:24:24 PM »
Yeah.  Angled shaft?
Re: D44 or D60?
« Reply #21 on: February 14, 2013, 09:26:20 PM »
Yea, it will be fine.
Re: D44 or D60?
« Reply #22 on: February 15, 2013, 08:23:52 AM »
My rear shafts are still stock.  Only put longs and fuses in the front.  Been fine for me.  One guy I know took out a rear shaft and that was with a 4.3 and a heavy 4 door sidekick, other than that just R&P failures
Re: D44 or D60?
« Reply #23 on: February 15, 2013, 08:29:58 AM »
I'm stock, welded, full hydro.  According to pirate I shouldn't be able to drive it out of the garage with out breaking :)
Re: D44 or D60?
« Reply #24 on: February 15, 2013, 08:41:43 AM »
The problem is it won't even drive out of the garage!  :)
Re: D44 or D60?
« Reply #25 on: February 15, 2013, 08:43:23 AM »
Im just thinking cost, Toyota axles will require Longs or Dirty 30s, and be limited to 37" tires for a buggy. Tons I can keep stock, put in 35 spline outers and be good for any size tires. If I am going to change it up, now is the time.
Re: D44 or D60?
« Reply #26 on: February 15, 2013, 09:53:51 AM »
Re: D44 or D60?
« Reply #27 on: February 15, 2013, 09:59:47 AM »
you can tell they are from PA... set of REARS!!!  I only see one rear and one front!!
Re: D44 or D60?
« Reply #28 on: February 15, 2013, 10:10:45 AM »
fawking "rears"  ::)
wouldnt that be a 60 and 70? also front is CAD.
Re: D44 or D60?
« Reply #29 on: February 15, 2013, 10:11:32 AM »
what side drop do you need on the front rear?
