Author Topic: 1973 CJ6  (Read 172341 times)
« Reply #450 on: September 18, 2014, 12:34:22 PM »
On the diff cover, bolts are even and not overtorqued? Just have some schmutz in there since those should be really forgiving in general.
If you hadn't found a PS pressure hose I was going to suggest Parker Hannifin to make one. Scout box swap in the Dakota req'd a visit therr
« Reply #451 on: September 18, 2014, 12:39:00 PM »
buy whatever two lines you want and swedgelock them together- what is on my ZJ right now haha
diff cover- lube locker gaskets suck i have bead that to death
« Reply #452 on: September 18, 2014, 01:50:04 PM »
I want to have off the shelf parts availability..  I found an adapter fitting that im going to try this weekend..
Lube Lockers have always worked for me...
I actually used it due to the fact I had a leak already with RTV..
ill prob check torque and see if it still leaks..  if it stops it will be good enough till running
« Reply #453 on: September 19, 2014, 09:08:59 AM »
and soon after stumbling block comes the first issue...
been having an issue with the electrical system.
much of the harness and dash is hooked up more or less.  I was testing circuits by toggling switches etc as usual.
Wiper switch was not working, took power wire off to check and no juice.
turned ignition switch off then on again, still no juice
repeated and now no ignition (Howell FP etc)
pulled maxi fuse and cursed and screamed..
came back to it after a beverage, put max fuse in and had ignition, but still no wiper power.
cycle continued again before I called it a night.
absolutely going to call painless today, but has anybody run into something like this?
could it be miss wiring or a faulty electrical product?  Harness bad?
My grounds are solid.. I have been paying very close attention to them.
« Reply #454 on: September 21, 2014, 09:21:28 PM »
Any relays or breakers between?
« Reply #455 on: September 24, 2014, 12:00:53 PM »
Little update on my electrical issue  and web wheeling trail damage…
Electrical gremlins ended up being some poor spade connectors on the ignition switch..
I have to say the painless harness is very easy to troubleshoot even for an electrical dolt like me.
Ignition switch acts as a distribution for Acc. and dash power… wasn’t getting a good connection from the main power supply.
Web wheeling trail damage is being defined as:
The act of redoing what one already did due to better or worse information found on the internet, most likely provided by people who haven’t actually done the modification or repair.
Ended up swapping out my PS pump for another unit.  O ring vs. Flare pressure line fitting was getting to me..
Then of course there are the different pulley setups to contend with.  Ended up using a Wagoneer pump and pulley, CJ pressure line and an adapter fitting.  Made some mounting studs instead of bolts and should be all good.
« Reply #456 on: October 12, 2014, 10:40:54 AM »
I have a runner... ;D
moved in and out of garage under own power...
Motor issues..
pressure relief valve leak (needs copper washer)
driver side valve cover not sealed well..  oil leak (this will be a PITA..)
Power steering pump pulley not 100% parallel with crank pulley.. needs to be shimmed..
Pictures and updates later today
« Reply #457 on: October 12, 2014, 10:50:07 AM »
Awesome!!
« Reply #458 on: October 16, 2014, 03:05:16 PM »
« Reply #459 on: October 18, 2014, 12:40:27 PM »
awesome
« Reply #460 on: October 20, 2014, 09:58:29 AM »
Time for a real update...
Still tackling some of the more PITA wiring chores..  trying to button up the dash so I can perm mount the Heat/AC unit.
Working on the turn signal switch and other dash wire chores.
gauge cluster is kinda working, need to spend some time in there with a test light.
Still need to cut another hole in the dash for the aux switch pod... just want to get the wires I have in there already termed and functioning.
Got the air handler all mocked up.
AC lines shouldn't be an issue.. it will be tight under there, but manageable.
Going to need to replace the bulk coolant lines with some 90 deg elbows to allow for best coolant flow.
Both fenders on and perm mounted...
starting to load up the interior with crap...  It was a small celebration when both the coolant and washer fluid fell snuggly into place.  I think I am going to add some weather pack connectors in the main harness if the fender or grill ever needs to come off..
Rear of the Jeep came out nice..
just need to drill holes for the tailgate and fabricate a way to latch it. (Factory tub had chain tabs.. not present on Aqualu)
threw the trans into reverse and to my surprise the single diode backup light switched on.  I think I'm going to use these on the YJ so I can finally be street legal after all these years.
Motor is purring and after swapping out the driver side valve cover gasket and a new copper washer in the oil filter housing i'm running leak free, for now....
Still haven't ran it for more than a few min.. given that I don't have a full exhaust system on the truck.
Need to get a good period where I'm home alone for a half hour to break this sucker in.
A short little video of it running... with good PC speakers you can hear the grunt!
« Reply #461 on: October 20, 2014, 11:12:02 AM »
It's the home stretch! Details take the longest for sure but that's close enough for some real motivation, looks great
« Reply #462 on: October 20, 2014, 12:22:45 PM »
ed, has those same windshield hold down knobs brackets.  they dont hold the windsheild straight for shit.  soft top pulls it back too far, doors dont fit, back window is flopping.  boo
« Reply #463 on: October 20, 2014, 01:05:53 PM »
 I can adjust the rake very easily..
shouldn't be difficult to adjust..
I mocked up my fiberglass doors and they both fit snug..
« Reply #464 on: October 20, 2014, 03:16:58 PM »
does your dash have the grip teeth brackets like OE does?  i think he is missing parts, next time can you take a pic of that assembly.
