Author Topic: Matts 93 YJ  (Read 29391 times)
Matts 93 YJ
« on: January 16, 2012, 09:48:46 AM »
8.8 swap completed
Driverside Motor mount replaced
Trans swap tomorrow.
Re: Matts 93 YJ
« Reply #1 on: January 17, 2012, 09:15:28 AM »
she is drying off in the shop!
Re: Matts 93 YJ
« Reply #2 on: January 18, 2012, 09:55:38 AM »
what a pile, this thing won like rounds 1-3 so far
Re: Matts 93 YJ
« Reply #3 on: January 18, 2012, 10:00:11 AM »
Is the transmission in neutral? When I did my truck I did not have it in neutral and the stick would go in fine but it just would not shift. I had to pull the stick out and shift it by hand into neutral them everything worked good. Just curious if that is your problem
Re: Matts 93 YJ
« Reply #4 on: January 18, 2012, 10:03:15 AM »
ill try that first but im gona say that should not matter at all as long as the stick is put in properly.  i had to have fucked up putting in the main fork i blame matt for worrying about where RTV was when i was putting on the back half of the case!
Re: Matts 93 YJ
« Reply #5 on: January 18, 2012, 10:09:14 AM »
My truck stick goes in the exact same there is no way to put it in "properly" just put it in.
Re: Matts 93 YJ
« Reply #6 on: January 18, 2012, 10:10:59 AM »
this ax5 is a ball that goes into a socket.... you really cant f it up....
Re: Matts 93 YJ
« Reply #7 on: January 18, 2012, 10:41:48 AM »
NV4500 and RTOO9513 both have the stick go through into the actual shift forks, if it's not in N it's somewhere between a total bitch and impossible to get it placed right.
Re: Matts 93 YJ
« Reply #8 on: January 18, 2012, 01:13:40 PM »
Warming up for a I told ya so
Re: Matts 93 YJ
« Reply #9 on: January 18, 2012, 01:22:56 PM »
better get a good blanket
Re: Matts 93 YJ
« Reply #10 on: January 18, 2012, 06:14:49 PM »
Told ya so!!!
Re: Matts 93 YJ
« Reply #11 on: January 19, 2012, 01:08:29 AM »
nope, main fork was put in wrong....
nothing to do with the shifter because i already knew that.
road tested and good to go.
Re: Matts 93 YJ
« Reply #12 on: January 19, 2012, 10:04:09 AM »
Re: Matts 93 YJ
« Reply #13 on: January 19, 2012, 11:19:41 AM »
nick, hope folding your blanket wasnt too hard for your candy ass last night.
Re: Matts 93 YJ
« Reply #14 on: January 19, 2012, 11:43:00 AM »
