Author Topic: SOLD-Dana 60, 14 Bolt, Iroks and Beadlocks  (Read 5279 times)
wnyjpgy
« on: October 08, 2012, 02:16:13 PM »
78-79 High Pinion, Kingpin Dana 60, re-geared to 5.38, all new bearings and kingpins when re-geared, welded spider gears (teeth welded shut, not together to create a locker, carrier is un touched), Ruff Stuff Specialties diff cover, High Steer Arms, 1 ton tie rod ends, DOM tubing drag link and tie rod, blackbird custom truck brake brackets, Chevy calipers, Spicer u-joints, complete set of spare axle shafts and hubs.
Corporate 14 Bolt, re-geared to 5.38, all new bearings when re-geared welded spider gears (teeth welded shut, not together to create a locker, carrier is un touched), disk brakes, solid industries diff cover. Spare set of axle shafts.
(6) Super Swamper Irok Radials, 39.5 X 13.5 X 15. 2 of them were purchased last year (cost $1000 for 2)and have 2 rides on the 95% of tread remaining, the next 2 were purchased the year before and have 5  or so rides on them, 90% of the tread remaining. The final 2 are a few years old and have 50% tread remaining. All of them have a little rock rash on them, but none of them have any plugs. I also have 2 junk ones with large sidewall holes, that are good for kids swings or whatever (with the junk ones, 8 tires total).
(5) 15 X 8 Beadlock wheels, 4 of them have wide (fancier) bead lock rings and the 5th one has a basic ring, the 4 newer tires are mounted on the 4 matching wheels. These were summit wheels with a DIY4X4 weld on beadlock kit.
These are currently under my jeep and I would like to sell them as a package. $3500
 I would consider newer snow plows, tires between 35”-38” in trade, or possibly a Grand Cherokee, or Wagoneer (V8’s Only)
« Last Edit: October 22, 2012, 09:39:17 AM by wnyjpgy »
Re: Dana 60, 14 Bolt, Iroks and Beadlocks
« Reply #1 on: October 08, 2012, 02:25:54 PM »
I assume these are in a TJ? How is the suspension set up?
i need to crunch some numbers tonight. Please PM me a phone number where I can get ahold of you
Thanks,
Spencer
« Reply #2 on: October 08, 2012, 02:26:32 PM »
under a CJ 8,  Leaf spring hog.
« Reply #3 on: October 08, 2012, 02:35:05 PM »
buh bye Scrambler
« Reply #4 on: October 08, 2012, 02:36:51 PM »
josh is serous now
wnyjpgy
« Reply #5 on: October 08, 2012, 02:45:50 PM »
I went wheeling last weekend, and smoked the winch, plantery gears in the case are pissed, and I''ve had enough of it.
I need a 4 seater, and have a clean tj tub on my frame jig, I would like to build something a little smaller and more streetable than my current pig.
I have another set of axles, and a complete low mileage drivetrain, so we'll see. I could use a plow for the front of the new dodge though.
I'll also take paypal (plastic) if someone eats the percentage fee.
« Last Edit: October 08, 2012, 02:53:04 PM by wnyjpgy »
« Reply #6 on: October 08, 2012, 07:44:13 PM »
Thanks,
Spencer
i just cant swing this financially right now. good luck with the sale
wnyjpgy
« Reply #7 on: October 12, 2012, 09:28:46 AM »
Updated Price $3200 or best offer.
Accepting plastic through paypal.
« Reply #8 on: October 12, 2012, 10:04:28 AM »
is the truck for sale as is?
wnyjpgy
« Reply #9 on: October 12, 2012, 10:14:47 AM »
Could be.
Snow plow and all?
Would probably be 5k, with all of my extra parts. both tops, doors,etc
6k with everything I have tj tub and frame,
50K (92TBI 350, 5 speed, 241) drivetrain with labeled harness cluster etc. I have a pile of TJ springs, and drive shafts, and tbi stuff and harnesses, etc For you I might even thtow in a roller cart and frame jig.
wnyjpgy
« Reply #10 on: October 12, 2012, 11:31:36 AM »
Was Just sent a really nice Waggy by a friend,
I'll fire sale the axles wheels and tires for $2500 if they are picked up at my house.
« Reply #11 on: October 12, 2012, 01:41:23 PM »
Awesome deal.
I let some of my CT friends here know. I'm going to be in NY this weekend with an emptry trailer heading back here Monday.
« Reply #12 on: October 12, 2012, 02:20:10 PM »
That is a great deal, someone building a buggy should pick them up and sell the tires for $1500
wnyjpgy
« Reply #13 on: October 12, 2012, 03:04:58 PM »
Thanks guys.
Keep me posted.
wnyjpgy
« Reply #14 on: October 19, 2012, 08:06:50 AM »
Going Once........
