Author Topic: 4-seat Ultra 4 buggy  (Read 4236 times)
« on: August 19, 2012, 10:08:59 PM »
This is my 4-seat buggy that we raced this season at RcRocs and RCQ. It is built to pass Ultra 4 tech, and has at RCQ. It is a good dual purpose machine, we trail ride and race it.
6.0 Chevy from a 2006 Silverado (LQ4) 89000 miles
Computer tuned by LT1swap.com
4l80E 2-wheel drive trans out of the same 2006 Chevy
Winters cable shifter
205 divorced transfer case (spare is included)
1410 U-Joints in the driveshafts
Chevy D60 Front Yukon 4340 Shafts 4.10 gears
35 spline outers
14b FF rear 4.10 gears Disc Brake swap
Ruffstuff pinion guard
Ruffstuff diff covers
Trail gear double ended ram
Trail Gear orbital
PSC wheel with quick disconnect
PSC column
Artec front truss and ram mount
Artec steering arms, connect to the factory arms for a stronger knuckle
ARP studs for the arms
Ruffstuff ¾ ⅞ steering heims
RPM off road heavy duty 35 spline drive flanges
39.5”x13.5”x17” Irok Bias (5)
17” DIY beadlocks on Cragar Soft 8s (5)
Chassis built by M4 fab 1.75”x.120”
2x2x.250” Subframe
⅜” ruffstuff tabs at axles and frame
1.25” RuffStuff heims at axle end steel bushings at frame end
E2000 fuel pump, with spare
Double triangulated 4-links front and rear
2x2x.250” Links square
Profender 2” remote res coilovers for coil carriers in front (no valving)
Profender 2.5” triple bypass shocks in front
Profender 3” travel 2.0 bump stops in front
Profender 2.5” Coilovers in rear
Corbeau Baja SS front
Corbeau Baja Bench rear seat 42”
Derale Trans cooler with 10” fan
Oil and Power steering coolers
Dual pass aluminum radiator
Autometer Phantom 2-5/8” gauges (water temp, trans temp, oil pressure)
Eagle 500C GPS
22 Gallon Summit fuel cell, Steel with plastic bladder
Remote fuel fill
Hi-Lift jack mount
Amber, red and blue lights, including brake light
Power brakes (vacuum assist)
PRP 5- point harnesses in front ( These are the best harnesses on the market)
PRP 4- points in the rear (seat belt style so the kids can buckle themselves in)
Custom window nets
Engo 9000lbs winch with Synthetic line
10” LED flood pattern light bar
All that is needed to be 100% to KOH rules is fuel shutoffs on all the lines and a line lock or parking brake of some kind.
$19000 not looking for trades
Re: 4-seat Ultra 4 buggy
« Reply #1 on: August 21, 2012, 08:55:04 PM »
Here is a beauty of a PM i received.
It on the trail or trailer just others and how do you enter koh can you just go race
« Reply #2 on: August 21, 2012, 09:33:04 PM »
That's some great engrish skills.
« Reply #3 on: August 21, 2012, 09:46:28 PM »
Fix those harnesses before you die!
« Reply #4 on: August 21, 2012, 10:12:20 PM »
Haha. Gotta love the know it all's on Pirate.
I told the guy to show up and race. :))
« Reply #5 on: August 22, 2012, 12:08:24 AM »
What in the flaming mother fucking fuck does that even fucking pretend to fucking mean?! Fuck!
« Reply #6 on: August 22, 2012, 09:42:51 AM »
That's a whole lotta F bombs... N bomb!
Sent from my DROID3 using Tapatalk 2
« Reply #7 on: August 29, 2012, 11:25:46 AM »
Deposit being wired today
