Author Topic: Land Rover 109  (Read 61555 times)
Re: Land Rover 109
« Reply #195 on: September 14, 2016, 11:33:09 PM »
Crush sleeve or shimmed?
If its shimmed and shimmed right, tighten the dogshit out of it weld the nut and ignore it
Re: Land Rover 109
« Reply #196 on: September 15, 2016, 12:10:25 AM »
get an over haul kit for it, i can go through it, and weld the nut.
i thought it was a dana60?
Re: Land Rover 109
« Reply #197 on: September 15, 2016, 07:38:56 AM »
really???
I'm taking it out of the truck.. easier to deal with and it only took 45 min to disassemble..
felt like i needed to do something last night
its a Dana 60 center section as far as this is concerned..
bearings no problem, seals no problem..
gear set and carrier are different but interchangeable..
issue is, no 4.7:1 ratio for a "Dana 60"  and yoke is different
doing some homework today to see what options are..
Re: Land Rover 109
« Reply #198 on: September 15, 2016, 07:40:04 AM »
crush..
i remember the first time i changed the seal, instruction were to mark location and depth on pinion as to not overdo it..
Re: Land Rover 109
« Reply #199 on: September 15, 2016, 09:46:01 AM »
use a normal 1/2" ratchet and tighten the nut as tight as you can get it.  red lock tight, or peen / sqush the nut before you re install.
 no normal man without a cheater bar can further crush a crush sleeve.  everyone i have ever done takes a 3-4' bar and grunting to get it to move in the "crush" region.  an 18v dewalt impact wont crush it either.
Re: Land Rover 109
« Reply #200 on: September 15, 2016, 10:43:48 AM »
this might be the only way for the current moment..
seems British Dana 60 parts are harder to come by than American Dana 60 parts..
Re: Land Rover 109
« Reply #201 on: September 15, 2016, 10:46:12 AM »
928 and 572 all have welded pinnion nuts now.  too many failures costing gear sets.
Re: Land Rover 109
« Reply #202 on: September 15, 2016, 11:18:52 AM »
I got a call from a customer this AM..
hears through another shop I was asking about rear ends..
told me to drop it off tomorrow  ;D
don't know where this will go.. but im feeling better about it than 10 min ago
Re: Land Rover 109
« Reply #203 on: September 15, 2016, 02:27:59 PM »
571 front as well, if I recall right.
Re: Land Rover 109
« Reply #204 on: September 16, 2016, 08:43:02 AM »
SRT got a 1 ton upgrade last night
Re: Land Rover 109
« Reply #205 on: September 16, 2016, 09:16:09 AM »
that looks like a Dr Ng visit right there!
Re: Land Rover 109
« Reply #206 on: September 16, 2016, 09:58:29 AM »
Thought the same thing! Ooof!
Re: Land Rover 109
« Reply #207 on: September 16, 2016, 10:24:13 AM »
My people built the pyramids.. I got a couple tricks up my sleeve..
Re: Land Rover 109
« Reply #208 on: September 19, 2016, 01:48:44 PM »
pinion gear chewed...
new gear set on order
Re: Land Rover 109
« Reply #209 on: September 19, 2016, 01:50:29 PM »
preload/pinion bearing i assume caused failure?
