Author Topic: Land Rover 109  (Read 61506 times)
Re: Land Rover 109
« Reply #120 on: December 01, 2014, 11:24:53 AM »
Wild. Prescision bushmechanicary!
Re: Land Rover 109
« Reply #121 on: December 01, 2014, 11:28:28 AM »
its a pain in the dick....
trucks deff designed for dirt cheap labor costs...
when your paying your mechanic in ivory or blood diamonds I guess it doesn't matter how long its takes or how many times you need to do it..
but its amazing.. EVERYTHING is rebuildable or serviceable to some extent..
snapped a distributor cap clip...
looked closely at it after cursing and noticed the clips are help in place by screws...
went to the parts bin, old distrib, same clip, new screw, problem solved.
tony
  • Come and take it
Re: Land Rover 109
« Reply #122 on: December 02, 2014, 09:46:58 AM »
What engine is in this 6-8? Na?
Re: Land Rover 109
« Reply #123 on: December 02, 2014, 10:19:45 AM »
trucks runs either a petrol or diesel in stock form..
2.25 L 73 hp (54 kW) I4 (Petrol)
2.25 L 62 hp (46 kW) I4 (Diesel)
obviously there are swaps and later engines but most series trucks are these guys...
My truck is running a hot rod tractor engine..
remember they are F heads..
its a Turner HP motor..
later 2.5 cam, boosted compression from 7:1 to 9:1 with extensive head work.
Running a Rochester Carb vs the stock Zenith.. about 40 more CFM..
it slugs about 100 HP.. can do 70, but its happy at 60-65 in overdrive
Just for comparison..
Jeep F-Head was 75 hp (56 kW; 76 PS) at 4000 rpm and 114 lb·ft (155 N·m) of torque at 2000 rpm with a 7.5:1 compression ratio.
that's a peak number.. Jeep dropped the compression on later F heads
Re: Land Rover 109
« Reply #124 on: December 15, 2014, 10:52:09 AM »
Engine back in.. heavy lifting is over..
New flywheel and Clutch components, new blasted and cleared flywheel housing,  Exhaust manifold back from JET HOT.
Amazing how difficult the flywheel cover O ring was to seat and install without squishing.
Unsure if I am going to really do EVERYTHING I was planning on doing.. its getting snowy and salty up here, need to get it into hibernation.
The long and short list as of now:
Engine:
Install Manifolds
connect exhaust
Carb/linkage/fuel lines
Coolant hoses
New Radiator or repair
Speedo cable @ Tcase
Oil pressure line / Oil filter / Oil
Clutch line (one continuous not 3 piece)
Adjust valves / Plugs / Wires
Rocker cover / Breather / oil cap
some new wiring / starter solenoid
Drivetrain:
fluid service
Dynamat transmission tunnel
Rear Axle:
Brakes
Pinion seal
Misc:
Blower motor seal
Suspension / Steering: Spring 2015
measure and weigh for new springs, order before 12/31 (Alcan)
Shocks? (OME)
rebuild steering
Winch:
Koning rebuild
Driveshaft
Re: Land Rover 109
« Reply #125 on: December 16, 2014, 10:24:35 PM »
Radiator being repaired, yay
Snobby British parts, shipped from Arab lands, installed by a minority Caucasian to travel the urban ghetto of rochester.
Worldly vehicle indeed.
Re: Land Rover 109
« Reply #126 on: December 17, 2014, 07:36:17 AM »
haha
Re: Land Rover 109
« Reply #127 on: December 17, 2014, 10:47:23 AM »
Called Alcan today....
getting some data for new front springs...
tempting me to build and design some new springs with orbit eyes for the YJ  ::)
Re: Land Rover 109
« Reply #128 on: December 20, 2014, 05:26:30 PM »
got a good amount of tasks accomplished during nap time... in good position to settle this us after bedtime...
Will need to be done after engine associated jobs are complete..
Install Manifolds
connect exhaust
Carb / linkage / fuel lines
Coolant hoses
Drivetrain:
fluid service
Rear Axle:
Brakes
Pinion seal
Misc:
Blower motor seal
Shocks? (OME)
rebuild steering
Winch:
Koning rebuild
Driveshaft
« Last Edit: December 20, 2014, 11:28:56 PM by rejeep »
Re: Land Rover 109
« Reply #129 on: December 29, 2014, 11:38:29 AM »
Right before Christmas in true British manor I stayed the course, and while caring for an infant and maintaining a home, I managed to get the Rover back running.  Didn't touch or attempt everything that needs to be done, just wanted to get the beast fired up so I can put some miles on the new seals, clutch and adjust valves before I put away for winter.  Motor fired right up once I got the wiring figured out..
was in such a rush to pull solenoid I didn't label wires and had to figure out how the Hi Torque starter was wired.  I think I am going to swap some wires around and change how it gets power..  I currently have the trigger wire going to the solenoid on the starter.. I think I like the idea of the bypass wire and keeping the harness stock..  Would also serve are a backup if the factory Lucas solenoid ever fails.
While examining the wiring the 40 year old charging system wires are beginning to fray and crack.. unsure if the >40 amps are actually getting to the truck..  I purchased a couple years ago a Delco SI conversion bracket from Pangolin 4x4..  I think its time to upgrade..  Dropping the brackets off to get dipped and ordered a new Alt from Delco..
will need to run some new wires.. much needed upgrade..
Got the truck up and running, ran some errands and even drove it for a bit…
Considering the valves had not been adjusted it fired up on the first crank with no issue…
Once I got home I went to start the truck again and there was nothing but smoke wafting from the dash…
Started on dash removal to investigate the cause…… and this is what happened..  Needless to say I have another project to finish up before putting miles on…
Why stop there right?  If I’m going to take a  bite out of something might as well be a big bite…
Rear axle torn down:
Pinion seal
Brakes
Possible hub seal
Diff cover referb.
« Last Edit: December 29, 2014, 11:40:08 AM by rejeep »
Re: Land Rover 109
« Reply #130 on: December 29, 2014, 11:46:43 AM »
I *hate* it when the magic smoke comes out. Source? Hopefully something easy to find and solve
Re: Land Rover 109
« Reply #131 on: December 29, 2014, 12:25:36 PM »
Sorting out the wiring may not be that bad.. waiting for the hard to source dash cowl will be the big problem.. mine is serviceable, but broke.
starter switch seems to be the issue.. when I rewired the ignition I am now sending full battery current through the ignition switch. ( the way oe had it)
Some melted spade connectors and corroded terminals are prob the cause.. it's a 40 year old rats nest back there.. going to clean it up and see if it holds.
Axle work is just time consuming.. parts are available and I don't think I'm touching the bearings..
Re: Land Rover 109
« Reply #132 on: December 29, 2014, 01:17:07 PM »
I'd like to shamelessly steal the DC power on banana plug idea. Make so much more sense than the cig lighter BS.
Re: Land Rover 109
« Reply #133 on: December 29, 2014, 01:42:55 PM »
they are avail afermarket
Re: Land Rover 109
« Reply #134 on: December 29, 2014, 01:55:25 PM »
I have a dozen red/black both sexes sitting on my desk. Dense me... never even considered it until I noticed them on your dash. I seriously need to invest in a larger coffee pot.
