Author Topic: Fix the wedge  (Read 45989 times)
Re: Fix the wedge
« Reply #75 on: June 13, 2012, 04:00:39 PM »
i have 10" wide by 8' sheets of 1/4" in stock i think, nut sure how much i chewed through
Re: Fix the wedge
« Reply #76 on: June 14, 2012, 10:38:11 AM »
Alex got me a 3' chunk of 4x4 at Surplus this morning. Was all they had in drops unfortunately. Sorry Matt!
Fix the wedge
« Reply #77 on: June 15, 2012, 12:25:33 AM »
$30 off $57.57 at Advance tonight. All wedge lights are now legal. Fixed the bad tail light in the ram. Gooseneck lowered, adjustment lock bolts done. Adjusted toe in one turn; probably needs more. Working late blows, didn't get started until 7 or 8.
Going to use the chunk of 2" tube I got from smike last night and plumb the transfer tank before I call it a night. I think that was the last think on my "now" list.
awl4928
Fix the wedge
« Reply #78 on: June 15, 2012, 03:14:32 AM »
How did you get 30$ off at advanced?
Re: Fix the wedge
« Reply #79 on: June 15, 2012, 08:14:57 AM »
i am guessing six 5$ off monster jam coupons and a helpful cashier lol
Re: Fix the wedge
« Reply #80 on: June 15, 2012, 08:26:56 AM »
haha 1 item at a time please :)
Re: Fix the wedge
« Reply #81 on: June 15, 2012, 08:30:06 AM »
I order stuff online and use coupon codes, then pick up in store. It works great.
Fix the wedge
« Reply #82 on: June 15, 2012, 08:57:26 AM »
Thank you Monster Jam sponsorship. And Paul, Erica, and good timing for an empty store to waste the time.
Fix the wedge
« Reply #83 on: June 15, 2012, 07:07:39 PM »
All loaded up and sitting down to dinner at Outback.
Had a few minutes to kill so I checked a
height. Liberty is 5'9" tall, and forward facing on the top of the trailer (not on the flip outs) it makes me about 11'4". I raised the coupler 2-3" last night too.
Mazda2 a little further back puts me at 10'2".
Re: Fix the wedge
« Reply #84 on: June 15, 2012, 10:39:27 PM »
Are you coming back full?
Fix the wedge
« Reply #85 on: June 16, 2012, 12:25:08 AM »
2 pickup trucks returning, so I guess I have one spot open from DC (thats the Liberty destination) to Norfolk VA and back.
Re: Fix the wedge
« Reply #86 on: June 16, 2012, 09:21:45 PM »
I want a cheap VW convertible, Rabbit or Cabrio.  8)
Fix the wedge
« Reply #87 on: June 16, 2012, 10:01:19 PM »
That would be fun.
Saw this, also fun. Not for sale...
Long day of fuel issues today. I noticed 0psi fuel pressure on a climb last night before I stopped. No other symptom. Thought that was odd since I'd never seen such before and I'd just changed the filter a couple weeks ago.  Figured id pick up a spare filter today just in case.
Well this morning just in case turned into must. Zero pressure more often than not, and taking forever to come back up. I was pulling minor hills at 35 miles an hour. Sadly, the hour wasted changing the fuel filter and cleaning the screen made no difference at all.
I was down to about a quarter tank of fuel so I sort of suspected potential draw straw issue. I went to a Lowe's, and got proper parts to mate the two hoses, and draw straight from the auxiliary tank. Again, no change. Very mildly better from the additional pressure of a higher thank gravity feeding. Very mildly.
I called ahead to UCI Washington, the warehouse where I was going to deliver. Smitty had to call a store to check the part number, but they had one in stock, and he grabbed it for me. After I delivered and installed a new lift pump.  on the side of the road of course.
In addition to being a plain old pain in the dick, it gave me one difficult issue. One of the hard lines has a tapered fitting, and the collar would not spin on it. I probably spent half an hour working to break the collar free of the line. Think of trying to reuse an old brake line and its fitting.
Fix the wedge
« Reply #88 on: June 16, 2012, 10:08:42 PM »
 1956 California plate on the bug, by the way.
So once I got the pump replaced I fired the truck up, and everything seemed perfectly fine.
Once I started bopping down the road though, I started losing fuel pressure again. Along with my mind. After blowing some serious white smoke up a hill with the truck barely running, I noted that my fuel gauge was approximately 3/4. As soon as I pitched downhill, the truck ran great with good fuel pressure no matter how hard I beat on it. The auxiliary tank had completely emptied itself with the overflow valve adding half a tank of fuel to the main tank, exhausting the 25 gallons I'd put in the auxiliary.
I've never been so happy to be out of fuel in my life! I pulled over on the side of I495 on the MD side of DC and hooked the fuel feel back up tithe main tank. Aside from getting diesel in my eye when the barbs let go suddenly all went as planned. Zero fuel issues since.
So the protip of the day is: don't run out of fuel right after you change a lift pump. The symptoms look confusingly similar!
And no, I don't owe Nick $5. It's a little late, and that's more parts that transferred from the old motor. 305,000 miles at failure.
Fix the wedge
« Reply #89 on: July 01, 2012, 10:33:18 PM »
Hitch is awesome. Thanks a ton!!
Confirmed tire eating machine though. Right front is scrubbing the inside off. I have some tire swapping to do this week.
