Author Topic: 572  (Read 195572 times)
572
« on: June 04, 2012, 03:58:55 PM »
Just thinking aloud....
if i get two fabricated 9 housings one off set to the left and one off set to the right, i can build any off set diff car, front or rear engine, passenger diffs or driver diffs on both sides.... hmmm
Re: 572
« Reply #1 on: June 04, 2012, 04:02:43 PM »
offsetting both diffs?
isn't the 9" pattern reversible, too, so there is no right or left drop, just an offset (ignoring drain and fill holes I guess)
Re: 572
« Reply #2 on: June 04, 2012, 04:09:37 PM »
thats what im forgetting, if the pattern is flippable, ill have to look into that.
big choice is going to be spendy light 9's or do 14's   i have to do some reading on both, but one will happen.
ya i was thinking pass diffs but after Ryans comment nothing says i couldnt flip the other 60 i have, weld on solid C's corrected and run it.  new car will stay 4.10s in 1:2    70-80mph is plenty fast in the rocks  :)
Re: 572
« Reply #3 on: June 04, 2012, 04:18:16 PM »
lots of load on 4.10s apparently? can't believe Rywan's broke.
Re: 572
« Reply #4 on: June 04, 2012, 04:18:28 PM »
The TrueHi9 is one I always thought looked damn good. Prices are rough though as expected.
Re: 572
« Reply #5 on: June 04, 2012, 04:20:48 PM »
I would never ever run a hi-9. ever.
debatable reliability issues and SHIT support issues.
Re: 572
« Reply #6 on: June 04, 2012, 04:21:29 PM »
With some shock tuning and good steering I don't think it would be too used up and would be a top contender. You can really drive these days, no doubt about it.
So am I fired? :)
571 might do the last RCrocs race with the motor as is.  im not going to put another one in it right now.
you are fired for 572.  :'(
plan to start bending tube in 2 weeks or so.   Time to build the car i should have built, the way i should have built it.
Re: 572
« Reply #7 on: June 04, 2012, 04:24:34 PM »
Really? I must be reading the wrong stuff... whoops
Re: 572
« Reply #8 on: June 04, 2012, 04:24:50 PM »
IDK, its all about the Benjamins.  ;D
Rausch style racing, would the 14b hold up better than the fabricated housings?
Re: 572
« Reply #9 on: June 04, 2012, 04:27:16 PM »
if i was going to run 9's id run the kind you find in junk yards, and have 2 spares.  if it really was an issue, id get rid of them.
my thought with running the 14's the wrong- it way would be as strong if not stronger than a 60
Re: 572
« Reply #10 on: June 04, 2012, 04:30:29 PM »
unsprung weight is the biggest performance killer in high speed and in "rock bouncing"
going 9's would be a huge weight benefit taking a ton off the car
Re: 572
« Reply #11 on: June 04, 2012, 04:34:42 PM »
6.0 motor? 4L80E?
572
« Reply #12 on: June 04, 2012, 04:37:55 PM »
Fancy hubs can save almost as much as the housing, but seems silly to put bling hubs on a junkyard lump.
Re: 572
« Reply #13 on: June 04, 2012, 04:43:57 PM »
Just out of curiosity, anyone running rcv's in ultra4? Glanced at my "rock bouncing" calender on the wall... 99% of those guys have em. Carrying entire spares (if you managed to break one) would obviously be next to impossible though.
Re: 572
« Reply #14 on: June 04, 2012, 04:56:38 PM »
another 5.3, and a BUILT th400 will be my flavor in the new car.
i dont need any more power than i have now, ill keep my yukon super shafts and make them stronger with a lighter car.
