Author Topic: 572  (Read 413082 times)
Re: 572
« Reply #1335 on: June 14, 2015, 09:26:25 AM »
koh flat Erik changed dismounted.  only a small pin hole found in the side wall..   easy patch.
Thanks again Erik and Cora for catching a hissing tire before i destroyed it!
You Betcha
Re: 572
« Reply #1336 on: June 16, 2015, 12:31:32 AM »
chassis power washed down again
front hydro lines and fittings re arranged for fix
fluid containment balloons swapped
i seem to have a bolt / miss alignment failure and not the actual heims that are wearing and causing the slop.  not sure whats up.
Re: 572
« Reply #1337 on: June 16, 2015, 11:01:28 AM »
You're still not on top locks, right? Could be loosening just a smidge and allowing some play/slam/wear?
Re: 572
« Reply #1338 on: June 16, 2015, 11:36:56 AM »
All top locked and checked tight at least 2x since KOH.  Heim ball doesnt move, bolt doesn move.  misallignment moves in heim and around bolt.
i did notice some of the tabs are not quite parallel and maybe edge loading the missalignment so might adjust and add some washers ect
Re: 572
« Reply #1339 on: June 16, 2015, 01:51:39 PM »
Could the misalignment spacers be just a little bit long inside the Heim joint?
I guess that would not explain the spacers moving on the bolt, just the ball around the spacers
Re: 572
« Reply #1340 on: June 16, 2015, 04:07:21 PM »
i think its just the softest material compared to the heim ball and the 3/4" bolt and it got beat.
We are changing to all Stainless steel misalignments for east coast problems.  i guess the strength will be      different.
CJ
Re: 572
« Reply #1341 on: June 16, 2015, 08:45:13 PM »
I can test hardness of old and new stainless spacers of you really want to know.
Re: 572
« Reply #1342 on: June 16, 2015, 11:15:42 PM »
i could to, and do a lot more at work- but it wouldnt matter.  we are stuck with what we have.  SS should be here tomorrow.
Re: 572
« Reply #1343 on: June 16, 2015, 11:17:01 PM »
wheel bearing service completed.
2 new KRTs mounted up, 3 more tomorrow after sifting though worst mounted on KMCs
Re: 572
« Reply #1344 on: June 17, 2015, 03:08:54 PM »
SS misalignments made it in today
Re: 572
« Reply #1345 on: June 18, 2015, 12:06:13 AM »
all new 3/4" grade 8 link hard ware and new SS misalignment spacers installed.  8 heims out of 12 changed for any kind of play.  front upper was fine on both ends, rear right side lower was fine.
all joints had crushed/worn misalignments as 90% of play.  looking at the thickness of the design, i think its just weak and crushes with race prep torque.  see how the SS work.  i didnt go nuts and only torqued with impact instead of 3' bar hump.
Re: 572
« Reply #1346 on: June 18, 2015, 07:58:41 AM »
1-1/4" Ruffstuff chryo Teflon etc etc heims?
Re: 572
« Reply #1347 on: June 18, 2015, 09:04:27 AM »
yes
Re: 572
« Reply #1348 on: June 18, 2015, 03:35:55 PM »
best i can tell for 572
LR 150 / 250   16/18 @ 33.3" free height __ shaft
RR 150 / 250   16/18 @ 33.0" free height __ shaft
LF 125/150 14/14   @ ____ free height __ shaft
RF 125/150 14/14   @____ free height __ shaft
Re: 572
« Reply #1349 on: June 19, 2015, 12:39:22 AM »
new tins and tree bars on tonight
