Author Topic: Used Up  (Read 40627 times)
Re: Used Up
« Reply #120 on: August 18, 2013, 11:47:39 PM »
All Saginaw style can be tapped - so, yes.
Might be worthwhile.
I have two two batteries on my bench, I think they're both good. I thought the one in the Dakota was good too though so who knows. Probably will need to do some battery cable/terminal magic. Hopefully I'll get my fourth "lifetime" pump tomorrow.
Re: Used Up
« Reply #121 on: August 18, 2013, 11:51:54 PM »
needs more tube and less mopar this winter
Re: Used Up
« Reply #122 on: August 19, 2013, 11:04:08 AM »
needs to be crushed this winter is what that boils to
Re: Used Up
« Reply #123 on: August 19, 2013, 11:10:33 AM »
pull the cab off and crush that.  cut the frame where its cracked, half back it out with tube.  Mount seats and hydro, and find 3 wires to run motor.  Fuel cell it, air shock the front, buggy leave the rear for now.
Re: Used Up
« Reply #124 on: August 19, 2013, 11:14:32 AM »
Re: Used Up
« Reply #125 on: August 19, 2013, 11:58:53 AM »
You coming to Rausch this weekend?!
carchameleon
Re: Used Up
« Reply #126 on: August 19, 2013, 11:07:50 PM »
Yes he is,  with the Dakota and my cj in tow  :)
Re: Used Up
« Reply #127 on: August 20, 2013, 12:28:40 AM »
I said weeks ago I was in. We'll see if the Dakota makes it. No progress attempted tonight.
Re: Used Up
« Reply #128 on: August 20, 2013, 10:19:45 PM »
Fresh ps pump installed. Fresh battery and some frame welding tmw. Then see how she drives...
The bench batteries should be good - they came from the Dumpbus.
Re: Used Up
« Reply #129 on: August 20, 2013, 10:52:50 PM »
Awesome!
Re: Used Up
« Reply #130 on: August 21, 2013, 06:48:18 AM »
Holy crap...
I wanna go just to see the Dakota again.
Re: Used Up
« Reply #131 on: August 21, 2013, 07:23:04 PM »
Still leaks from the box. Doesn't pour though - just leaks.
Would need an O2 sensor to get a sticker. P0132s don't really go away without one of those. Old one is snapped off, as I recall I killed it in the drowning and couldn't get it out.
Re: Used Up
« Reply #132 on: August 21, 2013, 09:04:02 PM »
I dunno. That's a pretty bad leak still. At least it holds fluid when shut off now, and will keep the system full for a half mile run down the street and back.
Everything else seems good enough. I should have checked stock at AZ again on that "lifetime" box and tried again to get another on the way, but I doubt an NLA part is gonna show up.
Could pull the box and try changing the cap seal? Rebuild lots had been in stock last year.
Other than that, as far as Smike's big ugly cooler hauler plan - it deserves an oil change, probably another trans fluid and filter along w a deep pan (lets see if it lasts a weekend first) and needs a tank of gas. I severed an OBA line in two places welding frame cracks and have that repaired.
Clicky rear driveshaft is not swapped out.
what should the last night's todo list be?
Re: Used Up
« Reply #133 on: August 22, 2013, 12:46:42 AM »
i read, spare fluids rack and air up the tires     8)
Re: Used Up
« Reply #134 on: August 22, 2013, 07:46:21 AM »
^^ agreed!
