Author Topic: 2023 Chevrolet Silverado ZR2  (Read 24991 times)
Re: 2023 Chevrolet Silverado ZR2
« Reply #15 on: June 26, 2025, 09:25:49 AM »
all about the hundredths of MPG multiplied fleetwide!
« Reply #16 on: October 23, 2025, 02:37:22 PM »
2 years now, no issues to speak of.   12.5k miles on it.
Haven't done the engine recall check yet, will do that when next oil change is due because new oil change is included in the recall no cost.
« Reply #17 on: October 23, 2025, 03:11:08 PM »
Is that the recall check where they basically redline the motor for 30minutes... if it stays running you are good, but if it fails you get a new engine?
« Reply #18 on: October 23, 2025, 03:33:12 PM »
sub 3 min video explaining the process https://www.youtube.com/watch?v=2Zv-t6kQ_ts
« Reply #19 on: October 23, 2025, 09:53:38 PM »
Curious what yall think of the picoscope test.  bs or good?
« Reply #20 on: October 27, 2025, 12:05:20 PM »
so looks like they have identified and RPM range that produces / aggravates an engine that has either no, some, or excessive worn bearings/tolerances and or excessive valve train knock/tapping that may or may not be heard by ear, but can be measured and recorded by a knock sensor (vibration sensor) and then they have grouped the recorded data into a pass fail based on if too much damage has been done or not, and then if ok add thicker oil to help it stay ok.  im sure they have a bunch of data and GM is like full force fire fighters.
they probably have fleet data that clearly explains what percent are bad, what percent make it to 50k, 100k, 150k ect and chose a best direction to cover their ass/ meet warranty requirements, or replace the engine if needed.
thats my 30 second understanding after watching the video and not researching the recall or any other related info.
« Reply #21 on: October 27, 2025, 12:36:59 PM »
I wonder how many of those engines will make it to 150k, 250k compared to previous generations? hopefully the viscosity change is a resolution and not just a delay of the inevitable.
« Reply #22 on: October 27, 2025, 12:42:55 PM »
im sure its a band aid to make them meet the requirements they were designed and sold to meet, so that is the resolution in the eyes of GM.  anything else, is bonus to customer, thats just how it works.
« Reply #23 on: October 27, 2025, 12:57:16 PM »
If engine fails test/deemed defective and replaced under warranty with new engine, the factory warranty remains original length.
If engine passes testing, warranty upgraded to 10yr/150k.
So... seems like life expectancy is 150k minimum.
« Last Edit: October 27, 2025, 01:00:11 PM by M »
« Reply #24 on: October 27, 2025, 03:20:16 PM »
probably expected to be 90-95%, then? any idea what their acceptable failure rates are?
« Reply #25 on: October 27, 2025, 03:23:15 PM »
8 yrs ago i could have answered that, as i was one of the group leads for reliability estimations lol
that proprietary knowledge has been round bin filed.
