Author Topic: 3 window chevy build on escalade chassis  (Read 71935 times)
Re: 3 window chevy build on escalade chassis
« Reply #45 on: October 05, 2023, 07:27:57 PM »
100 miles clocked on this thing after today!
« Reply #46 on: May 13, 2024, 08:25:58 PM »
some dumb b on her phone vered into my lane merging on to Jefferson road with hard curbs on both sides and almost wrecked me today.
I slammed on brakes hard enough i ended up in a 4 wheel slide at about 45 degrees to my original direction of travel.  throttle and steering was required to not case the curb as it was a 2 lane ramp with hard curbs
then later i coasted off of 531 out of fuel.  i guess 1/4 really means empty.  able to get it restarted and limp to a kwick fill at the first intersection barely lol
« Reply #47 on: May 30, 2024, 10:38:07 AM »
New quiet flow muffler installed this morning.  Zero drone or any more claptrap shit sound.  So much better and perfect amount of v8 when you stand on it.
Got its first hand wash!
« Reply #48 on: May 30, 2024, 02:51:58 PM »
I commented on that when you left last night. sounded a lot like the drone Eric was looking to remove from his Ram. Excellent!
« Reply #49 on: May 31, 2024, 12:48:21 PM »
for ref
Walker Quiet-Flow SS 21548 Direct Fit Exhaust Muffler 2.5" Inlet (ID) 2.5" Outlet (ID)
« Reply #50 on: June 17, 2024, 12:04:48 PM »
hit 1000 miles on this guy yesterday
doors got adjusted and much easier to open
exhaust much more pleasant.
needs to get on the lift next week- has some type of low speed rattle in the drive line since it was built- sounds like front drive shaft speed not wheel speed
« Reply #51 on: June 29, 2024, 11:08:51 AM »
some google foo
discovered common GMT800 front diff issue, there is a little stupid tab behind the driver side front diff output bearing that holds preload.  the only thing that holds the tab into the lock nut is the seal press.  the tab floats so you cant "peen" it over or lock it any other way.
popped out the cv and seal and with my finger could literally lift the side of the diff (and gear set?) about 1/16" of an inch.
tightened preload nut about 2 turns, seated lock tab, added a few shims and re installed seal after some bench straigthing where my 3 jaw slide puller kissed it a bit.
swapped in stock torsion keys back in to lift the front up a bit as its still rubbing on bumps and with 2 passengers its worse.
gave it a once over, all looks good.
getting loaded on a trailer to deliver to new owner tomorrow.    :-[
« Reply #52 on: June 29, 2024, 01:37:25 PM »
Oh wow! That post didn’t end where I thought it would
Nice!
« Reply #53 on: July 08, 2024, 02:01:34 PM »
buyer backed out.  says he just doesnt fit and cant do it with current knee issues.  he really loves the truck though.  o well.  to syracuse nationals it goes!
« Reply #54 on: September 24, 2024, 09:30:36 PM »
had a guy and his mechanic do a through inspection today on this
conclusion was loved truck and ok with price.  killed deal because of no heat and gas fill location.  he said it would be too cold and too hard to pick the ice away every week filling the gas in bed
wanted to have a winter driver  :o
freaking people
« Reply #55 on: September 25, 2024, 01:18:41 PM »
whaaaat
« Reply #56 on: May 13, 2025, 09:56:28 PM »
not much traction on sale of this.  a couple conversations and one ride along given
dont get it.
got a fresh NYS sticker slapped on it this week and reg renewed from winter storage.
bah.
« Reply #57 on: August 18, 2025, 04:24:24 PM »
took a deposit today.  another i have to deliver to CT bah
« Reply #58 on: August 19, 2025, 04:16:58 PM »
stickers and plates pulled, loaded for Thursday haul
« Reply #59 on: August 24, 2025, 01:18:54 PM »
dropped in CT,
SOLD
