Author Topic: 1930 Ford Model A Sedan  (Read 113971 times)
Re: 1930 Ford Model A Sedan
« Reply #135 on: November 17, 2024, 05:08:34 PM »
Cylinder hone complete.  1 min per/cyl    head mating surface cleaned and scratched with 120 grit.
« Reply #136 on: November 21, 2024, 08:50:49 PM »
New main bearings installed.  @ .0015
« Reply #137 on: November 22, 2024, 11:46:15 PM »
Rings and rod bearings installed.  Pistons installed.  Cam reinstalled. Timing gears, chain and chain guide installed.
This stuff takes forever...
« Reply #138 on: December 01, 2024, 12:16:36 AM »
Engine back together.  Going to leave the shinny bits off until I get it mated to the tranny and back in the chassis.
« Reply #139 on: December 07, 2024, 10:37:18 PM »
Transmission cleaned, new filter installed.  Waiting on pan gasket and rear seal.   Mated the engine and tranny and dropped it into the chassis.  Shifter gate modded for 4L80E and installed.
ebrake installed.
« Last Edit: December 07, 2024, 10:57:04 PM by gif »
« Reply #140 on: December 24, 2024, 04:44:19 PM »
Body on for the last time and bolted down.  Coolant system and grill installed.  Headlight buckets fitted with HELLA H4 100/80WTB High Wattage Bulbs and mounted.  Turn signals mounted.  Started populating the engine.  Waiting on 50lb/hr injectors.  Working on final brake, fuel and electrical connects.  Nicopp brake lines.  PTFE braided 6AN fuel lines.  1/0 AWG power wire for rear remote battery.  Hand wrapped custom engine wiring harness.
« Reply #141 on: January 02, 2025, 09:59:47 PM »
Engine wiring/harness done. Took longer because I cut every PCM wire to length so that it would look factory.   ::)
Rear of car (Turn/Stop lights, Tranny fan, Rev lights, Fuel pump, Sending unit) complete.  Starter wiring done.  Alternator wiring done.  Sill a long way to go for wiring.
« Last Edit: January 02, 2025, 10:20:33 PM by gif »
« Reply #142 on: January 04, 2025, 12:24:22 AM »
Front wiring done, except for the horn, somehow I lost it...  Was a cool vintage Indian motorcycle one.    Replacement re-pop on order.
« Last Edit: January 27, 2025, 01:18:20 PM by gif »
« Reply #143 on: January 18, 2025, 04:44:24 PM »
Wiring 100% complete.    Base tune configured.  Going to wait until spring and I can have the shop doors open before I fire it up.  Here is my tune log:
Edit Log for 1930 Model A Sedan 6.0L LQ4 DBC 4L80E OS12587603 Base Tune.bin created by TunerPro.
01/15/2025 10:02:38  Scalar:    G1201 - VATS (Vehicle Anti Theft System) changed from 0  (0x00) to 2  (0x02).
01/15/2025 10:21:26  Table:     B0101 - Main VE Table (Grams*Kelivin/kPa) changed.
01/15/2025 10:23:13  Table:     B0102 - VE While Cranking (Grams*Kelvin/kPa) changed.
01/15/2025 10:23:34  Scalar:    B0120 - RPM Threshold for Airflow Calculation changed from 4000 RPM (0x5000) to 400 RPM (0x0800).
01/15/2025 10:27:43  Table:     B5001 - MAF Sensor Calibration changed.
01/15/2025 10:33:17  Table:     B5001 - MAF Sensor Calibration changed.
01/15/2025 10:42:43  Table:     B4001 - Injector Flow Rate (Grams/sec) changed.
01/15/2025 10:44:48  Table:     B4003 - Minimum Injector Pulse Width (Milliseconds) changed.
01/15/2025 10:46:59  Table:     B3701 - Injector Pulse Width Voltage Adjustment changed.
01/15/2025 10:49:58  Flag:      G0106 - A/C Auto Recirculation changed from Set to Not Set..
01/15/2025 10:50:08  Scalar:    G0901 - Fan #1 Turn-on Temp changed from 284 Deg F (ECT) (0x0DFF) to 200 Deg F (ECT) (0x0955).
01/15/2025 10:50:14  Scalar:    G0902 - Fan #1 Turn-off Temp changed from 284 Deg F (ECT) (0x0DFF) to 190 Deg F (ECT) (0x08C7).
01/15/2025 10:50:36  Scalar:    G0904 - Fan #1 Turn-off Speed changed from 0 MPH (0x0000) to 45 MPH (0x1680).
01/15/2025 10:51:03  Scalar:    G0905 - Fan #1 Turn-on Speed changed from 0 MPH (0x0000) to 35 MPH (0x1180).
01/15/2025 10:51:41  Scalar:    G0906 - Fan #1 Turn-on Delay changed from 0.0 Seconds (0x0000) to 1.0 Seconds (0x00A0).
01/15/2025 10:51:48  Scalar:    G0907 - Fan #1 Turn-off Delay changed from 0.0 Seconds (0x0000) to 60.0 Seconds (0x2580).
01/15/2025 10:52:15  Scalar:    G0908 - Fan #1 Minimum On-Time changed from 0.0 Seconds (0x0000) to 60.0 Seconds (0x2580).
01/15/2025 10:52:55  Scalar:    G1203 - Type of Radiator Cooling Fans changed from 2 Fan Type (0x02) to 1 Fan Type (0x01).
01/15/2025 10:53:26  Scalar:    H0101 - Vehicle Speed Sensor (VSS) Pulses per Mile changed from 101605 Pulses / Mile (0x659B) to 94840 Pulses / Mile (0x5ED7).
01/15/2025 10:54:14  Scalar:    H0109 - Maximum Vehicle Speed (Non-ETC) changed from 98.0 MPH (0x3100) to 250.0 MPH (0x7D00).
01/15/2025 10:55:23  Flag:      B0701 - Catalytic Converter Protection Enable changed from Set to Not Set..
01/15/2025 10:55:47  Flag:      B1301 - EGR System Enable changed from Not Set to Set..
01/15/2025 10:56:05  Flag:      B1301 - EGR System Enable changed from Set to Not Set..
01/15/2025 10:56:57  Table:     G1207 - Vehicle Platform Options changed.
01/15/2025 10:59:05  Scalar:    B3608 - Delay Before Entering PE Mode changed from 60 Seconds (0x2580) to 0 Seconds (0x0000).
01/15/2025 10:59:39  Table:     B3609 - PE Delay Counter Adjustment (Seconds) changed.
01/15/2025 11:05:42  Scalar:    B3610 - PE Delay RPM Bypass changed from 5500 RPM (0x6E00) to 3600 RPM (0x4800).
01/15/2025 11:07:56  Table:     B3615 - Hot PE Mode Enable changed.
01/15/2025 11:08:16  Table:     B3616 - Normal PE Mode Enable changed.
01/15/2025 11:09:27  Table:     B3618 - PE Modifier Based on RPM changed.
01/15/2025 11:11:16  Table:     B4603 - Desired Idle Speeds changed.
01/15/2025 11:11:51  Table:     B4307 - Desired Airflow (grams/sec) changed.
01/15/2025 11:24:32  Table:     B5936 - Idle Underspeed Error changed.
01/15/2025 11:30:30  Table:     B5935 - Idle Overspeed Error changed.
01/15/2025 11:33:42  Scalar:    B4311 - Throttle Cracker Activate Speed changed from 9 MPH (0x0480) to 10 MPH (0x0500).
01/15/2025 11:35:18  Scalar:    B4312 - Throttle Cracker Deactivation Speed changed from 10 MPH (0x0500) to 9 MPH (0x0480).
01/15/2025 11:35:59  Scalar:    B1901 - Maximum Allowed Engine Torque changed from 350 Ft-lbs (0x4600) to 639 Ft-lbs (0x7FCD).
01/15/2025 11:36:13  Table:     B1902 - Torque Loss from Spark Retard (%) changed.
01/15/2025 11:36:29  Table:     B6605 - % Torque Loss from Spark Retard (Degrees) changed.
01/15/2025 11:37:19  Scalar:    B6616 - Maximum Rear Axle Torque changed from 10000 Ft-lbs (0x0007D00) to 41943040 Ft-lbs (0x8000000).
01/15/2025 11:37:27  Scalar:    B6617 - Maximum Front Driveshaft Torque changed from 2046 Ft-lbs (0x0001993) to 41943040 Ft-lbs (0x8000000).
01/15/2025 11:37:34  Scalar:    B6617 - Maximum Front Driveshaft Torque changed from 41943040 Ft-lbs (0x8000000) to 41943040 Ft-lbs (0x8000000).
01/15/2025 11:37:46  Scalar:    B6618 - Maximum Rear Driveshaft Torque changed from 2731 Ft-lbs (0x0002223) to 41943040 Ft-lbs (0x8000000).
01/15/2025 11:37:56  Scalar:    B6619 - Maximum Transmission Input Torque changed from 885 Ft-lbs (0x0000B10) to 41943040 Ft-lbs (0x8000000).
01/15/2025 11:38:07  Scalar:    B6620 - Maximum Transmission Output Torque changed from 2054 Ft-lbs (0x00019AC) to 41943040 Ft-lbs (0x8000000).
01/15/2025 11:38:21  Flag:      B6601 - Axle Torque Limiting changed from Set to Not Set..
01/15/2025 11:38:44  Scalar:    B6615 - Maximum Front Axle Torque changed from 9334 Ft-lbs (0x00074AC) to 41943040 Ft-lbs (0x8000000).
01/15/2025 11:42:56  Scalar:    B1201 - Abuse Management Upper RPM Threshold (in Gear) changed from 1400 RPM (0x1C00) to 7000 RPM (0x8C00).
01/15/2025 11:45:25  Table:     B6204 - Knock Retard Limit Not in PE Mode (Degrees) changed.
01/15/2025 11:45:49  Table:     B6205 - Knock Retard Limit When in PE Mode (Degrees) changed.
01/15/2025 11:52:25  Table:     B5954 - Burst Knock Delta Air Mass changed.
01/15/2025 11:55:48  Table:     B5908 - Fuel Mixture Spark Correction (Degrees) changed.
01/15/2025 11:57:13  Table:     B5907 - EGR Spark Correction (Degrees) changed.
01/15/2025 13:23:23  Table:     B5913 - Spark High-Octane Table (Degrees) changed.
01/15/2025 13:23:56  Table:     B5914 - Spark Low-Octane Table (Degrees) changed.
01/16/2025 10:27:02  Table:     C6001 - Diagnostic Trouble Code (DTC) Type changed.
01/16/2025 10:27:04  Table:     C6002 - Malfunction Indicator Lamp (MIL) Enable / Disable changed.
« Last Edit: January 18, 2025, 04:52:20 PM by gif »
« Reply #144 on: January 27, 2025, 01:17:44 PM »
Buttoning up this build.  Steering linkage installed and adjusted (1/8" toe).  Oil dipstick modded and installed.  Final install of the Ragtop.   I also added a wideband air fuel ratio gauge. I decided this was the build that I would force myself to learn MAF and Speed Desity tuning.  I figured with the changes I made to the engine this would be a good learning opportunity.  I will be using open source software tools.  TunerPro_RT / PCMHammer / Universal Patcher / Custom made Excel Sheets for graphs & Histograms.
« Reply #145 on: January 27, 2025, 01:20:41 PM »
cool, good luck with the tuning.  im going to try to learn as well this spring with my ecotec.
« Reply #146 on: January 27, 2025, 04:58:40 PM »
Gif, with all of the custom work you do, do you ever wish you had a car lift or not?
« Reply #147 on: January 31, 2025, 10:58:34 AM »
Yes, IF i had a larger shop.  A lift limits the shop layout.  It would be in my way when using the gantry crane. And I used that a lot.
« Reply #148 on: January 31, 2025, 03:07:53 PM »
Great build!
« Reply #149 on: March 17, 2025, 08:43:43 AM »
Filled the car with fluids and fired the engine this weekend.  Sounds angry.  8)
This worked great: https://www.youtube.com/shorts/bFzCrPtgD6M
Chased down a few small fuel and coolant leaks.
Ran the engine up to temp a couple of times to make sure the coolant was purged.
Next, need to get the tablet display finalized before I start messing with the tune.
Something up with the Oil Pressure PID in the Torque App and wont display.
But in the logger software I can see the oil pressure.
