Author Topic: 1930 Ford Model A Sedan  (Read 113826 times)
Re: 1930 Ford Model A Sedan
« Reply #30 on: March 27, 2023, 10:48:02 PM »
damn! speedy recovery. lung sounds the scariest bit of that by far
« Reply #31 on: March 28, 2023, 07:47:33 AM »
Ooof! Prayers for you my friend.
« Reply #32 on: March 28, 2023, 09:07:28 AM »
 :o
bah!
« Reply #33 on: March 28, 2023, 09:21:04 AM »
damn!  Sounds painful.   How's the healing process going to be like for that?  Are you in a body cast or what?
carchameleon
« Reply #34 on: March 28, 2023, 10:26:48 AM »
wow, speedy recovery.!
really cool idea for the front frame!
« Reply #35 on: March 28, 2023, 10:31:26 AM »
damn.. you seem to brake yourself quite often!
« Reply #36 on: March 29, 2023, 06:12:19 PM »
Dang
« Reply #37 on: April 09, 2023, 09:46:21 PM »
here are the Xrays showing the damage.  You can see the clavicle break right next to the hardware from the previous surgery. The last Xray has arrows pointing to the 5 broken ribs on my back.
« Reply #38 on: May 21, 2023, 08:28:08 PM »
Rear is a roller with 4 link and coilovers.
« Reply #39 on: May 21, 2023, 10:12:34 PM »
Hope that means recovery is going / has gone well!
« Reply #40 on: May 23, 2023, 07:54:03 AM »
Yup,  im @ 97%.   Final xRay next week.   Hope to be cleared for MTB season.
« Reply #41 on: June 11, 2023, 11:50:49 PM »
started mounting the engine/tranny.
« Reply #42 on: June 12, 2023, 09:20:25 PM »
Upside down mounts.?!    :o
Front crossmember/spring mount for front axle next.  I. have. a. plan....
« Reply #43 on: June 20, 2023, 10:00:11 PM »
Got the engine and tranny mounted.  clearance cut the firewall for the tranny.  Got body bolted back on.
Next started on the front crossmember.  this was a packaging nightmare,  but got it fitted and looks good.
Then worked on the radiator and shell mount.  takes time to get the design to be strong/easy to use/look clean.
And when your done it looks so simple...
« Last Edit: June 20, 2023, 10:05:16 PM by gif »
« Reply #44 on: June 20, 2023, 10:02:48 PM »
I had someone ask how i cut perfect circles for the fans.
I have a set of circle jigs i have made over the years.
