Author Topic: Ryan Larry Summer Salt ZJ Machine  (Read 75989 times)
Re: Ryan Larry Summer Salt ZJ Machine
« Reply #15 on: April 13, 2021, 04:54:46 PM »
pulled foam from fuel cell and cleaned that out.  fuel was red, thinking kerosene was in it or off road diesel?
Added a bulkhead fitting with a rollover vent i had. ordered 8AN to 3/8ths barb fittings.
Thinking im going to get a fuel pump, front drive shaft shortened and cobbled steering on this hawg to get her moving on her own at least.
« Reply #16 on: April 13, 2021, 05:30:50 PM »
I think I have some 5pt harness hardware laying around if you need
« Reply #17 on: April 13, 2021, 09:37:04 PM »
happy to take donations or old junk for this unit
« Reply #18 on: April 19, 2021, 09:47:13 PM »
ebay fuel pressure regulator was a joke, leaks from every interface, doesnt regulate pressure at all.
dead headed plumbed in a buggy pump and got it running by key (fuel pump heats up quick)
looked at drive shafts and started on steering.
« Reply #19 on: April 20, 2021, 11:20:23 AM »
front dana60 ford low pinion ball joint axle
yoke is for 1330 "big cap".
i don't understand how the ujoint is retained in the yoke side to side?  is there some ford magic hidden from the internet?  i see summit has girdle caps with tabs but they are to replace ujoint ubolts-  this yoke has threaded holes for straps?  its like i need a strap with a tab on the side to hold the caps centered?  doesn't appear to have any tabs broken off the yoke
anyone kknow whats up?
« Reply #20 on: April 20, 2021, 11:36:17 AM »
If it's low pinion and driver drop, it's likely a Dodge 2nd gen axle. Ford never did LP and ball joint that I'm aware of.
I believe that style yoke uses circlips on the caps that retain them against the inside of the yoke. I vaguely remember something like that with my 12 valve. Weird design.
« Reply #21 on: April 20, 2021, 11:37:28 AM »
ah, i get it.  scrapped at some goo and i guess there is a machined surface there
this looks to fit the bill with the measurements in the notes
https://www.amazon.com/Moog-372-Universal-Joint/dp/B009HQJGVW/ref=sr_1_1?dchild=1&keywords=moog+372&qid=1618932775&sr=8-1
« Reply #22 on: April 20, 2021, 11:38:23 AM »
dodge, ok sure.  that was throwing me too no wonder ha
« Reply #23 on: April 20, 2021, 11:40:11 AM »
Yeah i think that was a dodge axle with Ford outers
« Reply #24 on: April 20, 2021, 11:40:43 AM »
Its not ford lol.
look like dodge ram dana 60 via CAD
the u-joint have clips to keep it retained side to side, like axle shaft wheel u-joints
OEM is "Detroit 7290", per RockAuto
https://www.rockauto.com/en/moreinfo.php?pk=4937553&cc=1095904&jsn=556
edit: others posted faster than me. lol
« Last Edit: April 20, 2021, 11:49:23 AM by TrailTamer »
« Reply #25 on: April 20, 2021, 12:12:54 PM »
ya im needing a conversion joint for the front to just use the ZJ shaft after i shorten it and sleeve it with 2" 120wall DOM
Moog 372 is the right  1310 to 1330 big cap with internal C clips i found what i need to be least amount of pain and investemnt.  not worth a drive to ridge road to pay 2$ more than amazon will have one to my door in 2 days.
sorry not a ford or dodge front end expert i just remember nick saying something about Ford.
« Reply #27 on: April 20, 2021, 12:25:48 PM »
Could just gut the housing and lock the collar over both shafts and be done for free for a bit.
I honestly don’t know how often those break.
« Reply #28 on: April 20, 2021, 12:44:14 PM »
I did some research on CAD deletion on my truck a while ago and found that 99-04 Ford D50/D60 passenger side inner, 78-79 Ford D60 driver side inner are very close to correct length, close enough that I was willing try them if I didn't buy Yukon's full delete kit.
D50 use 30 spline if you're not going to swap out side gears from 30 to 35 spline in whatever carrier it have. problem is the passenger side inner axle shaft seal. I have not had my dodge d60's carrier out for several years now, cannot recall what it look like on inside on what off-the-shelf seal possibly will work to keep the cost down.
edit: that yukon's inner axle shaft seal is $$$$$$$$$$$$$$$$$. more than what I'll want to pay for them. about $100 each. https://www.yukongear.com/productdetails.aspx?ProdID=12135
« Last Edit: April 20, 2021, 12:51:09 PM by TrailTamer »
« Reply #29 on: April 20, 2021, 12:58:08 PM »
I have 2 of those dodge axles on the shelf. mule (95 v10 srw) and dumpbus (97 cummins dually). both should be full of lube so no easier than what's under the jeep now.
