Author Topic: Dump II: Santa's Ride  (Read 34509 times)
Re: Dump II: Santa's Ride
« Reply #60 on: September 13, 2012, 03:36:06 PM »
3k new
« Reply #61 on: September 13, 2012, 03:59:15 PM »
Just picked up the drive shaft $350 from fleet pride when cook brothers wanted 560 plus freight and tax
« Reply #62 on: September 13, 2012, 06:48:07 PM »
But is it right is the question
« Reply #63 on: September 13, 2012, 07:05:31 PM »
4-5 more tries and it'll be right. More new parts thrown at it but te price will stay the same.
Can't argue with results! Hahaha
« Reply #64 on: September 13, 2012, 07:21:09 PM »
I took the gamble we will find out
« Reply #65 on: September 16, 2012, 07:52:28 PM »
She has a big belly on her now! I used the original spots on the frame for the crossmember it lined up really close. Everything works good just drove it in the parking lot since the gallon or gallon and a half of oil mike had was not enough to fill it. Shifts just like a normal transmission real smooth and easy. The only thing I am not happy with is the mount I made to hold the clutch slave it works fine tho just sucks. Other than that she is sweet!
Sent from my DROIDX using Tapatalk 2
« Last Edit: September 16, 2012, 07:56:12 PM by Nick »
« Reply #66 on: September 17, 2012, 12:14:05 AM »
Damn, thought I had more left than that. Sorry it wasn't quite enough!
« Reply #67 on: September 17, 2012, 09:12:47 AM »
man she is no rock crawler, low ridding!
« Reply #68 on: September 17, 2012, 10:31:29 AM »
true dat. I guess twin countershaft is good for belly clearance at least :)
« Reply #69 on: September 17, 2012, 12:16:55 PM »
twin countershaft ftw!
« Reply #70 on: September 17, 2012, 12:24:44 PM »
I see some snazzy "stock" exhaust still fitting past that unit though. each has its clearance strengths!
« Reply #71 on: September 17, 2012, 12:46:18 PM »
unit, ha.
« Reply #72 on: September 17, 2012, 03:39:10 PM »
I won't be doing any rock crawling in 2wd anyways so it will be fine. Just got the oil from emerson and 5 gallons was the minimum I could order. Comes in at a sweet $166!!
« Reply #73 on: September 17, 2012, 05:01:32 PM »
suuuuuucks, was hoping there was a 1 gallon option.
« Reply #74 on: September 17, 2012, 06:43:01 PM »
Just drove this around for the last 30min or so and it shifts and drives so nice that the average person would probably not even realize anything is different from the normal stick. I also want to give a +1 to fleetpride for fit and balancing with the shaft.
