Author Topic: 1930 Ford Model A Coupe  (Read 106052 times)
Re: 1930 Ford Model A Coupe
« Reply #135 on: December 22, 2022, 06:48:48 PM »
Still working on the carpet and this happened.   Fresh utility blade is no joke.
« Reply #136 on: December 22, 2022, 07:37:47 PM »
Uncomfortably clean cut. Way to hold a straight line? Oof!
« Reply #137 on: December 22, 2022, 08:56:14 PM »
jumped the straight edge guide
« Reply #138 on: December 22, 2022, 10:13:46 PM »
Ooof
« Reply #139 on: December 23, 2022, 08:44:42 AM »
wow! thats impressive.  I always say you do impressive work.
« Reply #140 on: December 23, 2022, 09:28:22 AM »
youch
« Reply #141 on: December 25, 2022, 01:04:38 PM »
Interior complete.
« Reply #142 on: June 11, 2023, 11:37:17 PM »
Went to car show that was about an hour south of my house this weekend and noticed that the car had some hesitation.  Couldn't put my finger on it at first but then noticed it was when I drove over bumps/holes in the road.  So today I put the laptop on it and logged some driving data.   Here is what I found.  A first I thought it might be an overly sensitive knock sensor retarding the timing.  Thats how most GM engines are setup.   But when I looked at the data I saw the TPS dropping out.  Also see that the TPS is not at 0% when off the gas pedal.  The drop in TPS coincides with the timing drops.
Next tested the voltage at the sensor and it looked good.  Figured might have a bad TPS and swapped it out with one laying around, same result.  Thought more about the bumps causing the drop outs and started looking at the harness.   BINGO! found a spot were the harness was rubbing on the aluminum head where the cast was sharp and cut through the harness wrap and the wire insulation.  Working on a permanent solution...
« Reply #143 on: June 12, 2023, 10:10:14 AM »
nicely done diagnosis! that would have been a bear without the logs and that looks like an awful tiny rub spot
« Reply #144 on: June 12, 2023, 09:11:15 PM »
Thanks, this is why I love LS swaps.
« Reply #145 on: June 13, 2023, 08:16:11 PM »
Fixed wire insulation with dabs of high temp hot glue. Wrapped the harness with some anti-chafe sleeve and then re-wrapped it with harness tape.  Installed $30 in AN6 fuel line fittings to give the little more slack and change the fuel line path away from crowding the harness.  Add a few more zip ties...
« Reply #146 on: July 09, 2023, 07:31:49 PM »
Where was the show? Waterloo is a good drive from home!
« Reply #147 on: July 09, 2023, 08:03:22 PM »
Auburn, north end of Owasco lake. 1.5hr drive.
« Reply #148 on: July 11, 2023, 09:54:45 PM »
Found a broken grade 8 1/4-20 that holds the gas tank strap.  Upgraded to 5/16.
« Last Edit: July 11, 2023, 10:01:40 PM by gif »
« Reply #149 on: July 22, 2023, 02:29:13 PM »
I have been looking for black seats,  but so is everyone else..   So i decided to try vinyl paint for seats.  This is flat black.
I think it turned out pretty good.  Only time will tell how long it holds up.
