Author Topic: 1930 Ford Model A Coupe  (Read 106081 times)
Re: 1930 Ford Model A Coupe
« Reply #120 on: July 27, 2022, 02:01:36 PM »
Same but different.  8)
« Reply #121 on: July 27, 2022, 02:34:05 PM »
Looks like you need someone to drive your Apache around ;)
« Reply #122 on: July 27, 2022, 09:55:58 PM »
« Reply #123 on: August 02, 2022, 08:58:50 PM »
« Reply #124 on: August 02, 2022, 09:20:39 PM »
“Compact Cars Only”
« Reply #125 on: September 03, 2022, 07:56:24 PM »
Vintage plates  8)
« Reply #126 on: September 03, 2022, 08:24:02 PM »
As it should be!
Nice
« Reply #127 on: October 28, 2022, 01:12:37 PM »
« Reply #128 on: October 28, 2022, 02:57:52 PM »
Sweet pic!
« Reply #129 on: November 19, 2022, 03:32:24 PM »
Figured I should finish this one before I start the next.
Its a small to do list.
Replace the tranny mount with a stiffer Poly one.
Replace the leaky master brake cylinder (was new wtf)
Install interior. (jute/carpet/vinyl/tweed)
Got the new master cylinder in.
Started on the jute.
« Reply #130 on: November 25, 2022, 11:56:38 PM »
New poly tranny mount in.
All the jute is installed.
« Reply #131 on: November 26, 2022, 05:09:17 PM »
Hours to get this far.
« Reply #132 on: November 26, 2022, 05:14:22 PM »
is all that Jute like steamed in and glued down, or? so many puzzle pieces no matter the method
« Reply #133 on: November 26, 2022, 10:08:32 PM »
I hand cut each piece to fit. have to use serrated scissors to cut it.  Glued with 3M Super 77 industrial grade spray glue.  You spray the target area and then spray the back of jute/carpet.  Then put the jute/carpet on the target area. You get one shot because its high tack and bond strength.    :o
Jute is the easy part.  easy to hide mistakes.    Carpet takes time because it will show mistakes,  trim & test fit, repeat until perfect...
« Reply #134 on: November 27, 2022, 06:56:54 PM »
Doors are tweed and vinyl.     floor carpet complete.
