Author Topic: 571 RCQ prep  (Read 70362 times)
571 RCQ prep
« Reply #30 on: May 05, 2012, 01:10:56 AM »
That bed looks pretty nice...
Re: 571 RCQ prep
« Reply #31 on: May 05, 2012, 07:33:46 AM »
Smike I could probably scratch $500 together for that bed
Re: 571 RCQ prep
« Reply #32 on: May 05, 2012, 08:58:34 AM »
no go, just called its a Carb motor.
Re: 571 RCQ prep
« Reply #33 on: May 05, 2012, 09:52:05 AM »
found a 5.3 vortec with a harness local i think im going to give a try.  from a crashed 01
looks like all i need to bolt up my trans is this:
http://www.summitracing.com/parts/HUP-HP3795/
In 2001, GM - for the first time since 1955 - changed the crank depth and its pilot bore diameter of the Gen. III. Pilot bushings differ for these motors and transmissions built from this time forward had a deeper bellhousing and different torque converter.
571 RCQ prep
« Reply #35 on: May 05, 2012, 10:29:01 AM »
Do it. I have a FSM with wiring colors and a list of wires you need to keep. I can help with wiring if you need.
Re: 571 RCQ prep
« Reply #36 on: May 05, 2012, 11:55:06 AM »
Ya this with be a cheap soulution and ill get all the annoying shit for the next l33 build on the next car.
Re: 571 RCQ prep
« Reply #37 on: May 05, 2012, 08:19:51 PM »
someone come over and wire this bitch so i can go racing!
5.3 LM7  270hp factory?
motor and full harness picked up this morning, its in the buggy now.
Re: 571 RCQ prep
« Reply #38 on: May 05, 2012, 09:04:14 PM »
nice, you didnt have to make new motor mounts?
Re: 571 RCQ prep
« Reply #39 on: May 05, 2012, 09:06:45 PM »
probably not, but i have to get headers and a TC adaptor before i can get it mounted for good.  just wanted to hang it in and see if i had any major issues.
need to get a starter motor also.
571 RCQ prep
« Reply #40 on: May 05, 2012, 09:41:54 PM »
Nice
Re: 571 RCQ prep
« Reply #41 on: May 05, 2012, 09:59:13 PM »
Wiring it is not hard, I can have her running in an evening. You need the computer flashed before you get it going, or its gonna run in limp mode or something. Lots of things can be turned off and should be turned off. Trans controls, rear O2 sensors, Torque management, and other annoyances should be done away with.
Re: 571 RCQ prep
« Reply #42 on: May 05, 2012, 10:05:38 PM »
its got EGR that i took off also.
ya ill send out the ECM Monday, unless i can get people at work to do it.
Re: 571 RCQ prep
« Reply #43 on: May 05, 2012, 10:31:04 PM »
parts ordered from jegs. 1st time lets see how this one goes  lol
25$ for 6 11mm bolts, wTF uses 11mm bolts
Re: 571 RCQ prep
« Reply #44 on: May 05, 2012, 11:41:57 PM »
