Author Topic: 571 RCQ prep  (Read 70357 times)
Re: 571 RCQ prep
« Reply #15 on: May 02, 2012, 07:15:56 PM »
i think he talked me into pulling the pan, but really i see no point.  bah.
Re: 571 RCQ prep
« Reply #16 on: May 04, 2012, 12:37:43 AM »
motor and trans sitting on the floor.  need to grab  my stand from old shop and pull apart tomorrow to find goodness broken.
571 RCQ prep
« Reply #17 on: May 04, 2012, 07:56:17 AM »
Good job.
Re: 571 RCQ prep
« Reply #18 on: May 04, 2012, 08:08:03 AM »
wasnt too bad with the lift and new shop.
sweating concrete is annoyingly slippery though!
Re: 571 RCQ prep
« Reply #19 on: May 04, 2012, 08:20:51 AM »
Just replace it, why even bother looking at it?
Re: 571 RCQ prep
« Reply #20 on: May 04, 2012, 09:38:49 AM »
Troy should come grind the concrete and give it some texture!
look at it because it only makes noise so far, it's not really broken.  glad the lift improved the annoyance factor.
I only got ujoints done last night. Hope they were my problem.  Wrapped up just as the light show was starting, I didn't get dripped on.
Re: 571 RCQ prep
« Reply #21 on: May 04, 2012, 09:49:27 AM »
Best case is you replace main bearings and they last another race, then pull it again.
Worse case you pull it apart and discover scored cylinder walls from a broken piston, machine work and parts =$$$
Why not just replace it with one of the options and be done for another year? Why waste time diagnosing a problem just to replace it anyway? Time = money at M4 now.  8)
Re: 571 RCQ prep
« Reply #22 on: May 04, 2012, 10:01:58 AM »
no time wasted, the trans is going in for rebuild, and i need my HPHV oil pump since oil was clean.
Re: 571 RCQ prep
« Reply #23 on: May 04, 2012, 08:20:37 PM »
oil sump pickup was laying in the pan....
Re: 571 RCQ prep
« Reply #24 on: May 04, 2012, 08:37:21 PM »
Ouch...  di you have a pressure gauge.. or that hard to see like the voltage ?
Re: 571 RCQ prep
« Reply #25 on: May 04, 2012, 08:42:47 PM »
yes i have gages
571 RCQ prep
« Reply #26 on: May 04, 2012, 08:43:08 PM »
Not bad to see at all, and it never went to zero. I was watching it since as the motor got hotter the pressure would drop. Always at least 15-20 psi. P
Re: 571 RCQ prep
« Reply #27 on: May 04, 2012, 09:38:42 PM »
http://rochester.craigslist.org/cto/2959475891.html
flat bed worth anything to you aaron?
looks like sweet tires for the janitor
Re: 571 RCQ prep
« Reply #29 on: May 04, 2012, 10:06:01 PM »
it does not look to bad, would need to know the length from front to wheelwell to see if it would really fit... but no cash right now though
