Author Topic: 571 RCQ prep  (Read 70434 times)
Re: 571 RCQ prep
« Reply #120 on: May 17, 2012, 03:01:25 PM »
got it..
Re: 571 RCQ prep
« Reply #121 on: May 17, 2012, 05:00:52 PM »
i need a new one of these
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Pigtail-Socket-BWD_5973171-P_422_R%7CGRPSESWAMS_____
thats the right picture but got knows what they have it listed wrong as lol
Re: 571 RCQ prep
« Reply #122 on: May 17, 2012, 05:39:57 PM »
its a YJ brake pedal thingy????
just bought one the other day for myself..
Re: 571 RCQ prep
« Reply #123 on: May 17, 2012, 05:50:50 PM »
the brake assembly in 571 is actually out of my 75 CJ5 and uses the OEM brake switch.  i had replaced it with a new one from napa when i built the CJ but it has failed.
apparently it is a common part with AMC eagles, so rockauto says so    ;D
Re: 571 RCQ prep
« Reply #124 on: May 17, 2012, 05:52:21 PM »
man dont feel like chasing cerp belt sizes and idler / tensioners right now lol
Re: 571 RCQ prep
« Reply #125 on: May 17, 2012, 05:53:06 PM »
matt, mike should be at the shop after 7, leaving work shortly need to run to wegos.
Re: 571 RCQ prep
« Reply #126 on: May 17, 2012, 05:59:27 PM »
leaving work now, need to shop and pack tonight still too.
uugh
Re: 571 RCQ prep
« Reply #127 on: May 17, 2012, 06:02:00 PM »
remember i have nightly trucks down that way...
support those who support you!!!
Re: 571 RCQ prep
« Reply #128 on: May 18, 2012, 07:51:46 AM »
there are two 5.3's down in our storage probably headed for the scrap pile with 07' tags on them    :'(
Re: 571 RCQ prep
« Reply #129 on: May 18, 2012, 09:42:04 AM »
Very sad.....:'(
Re: 571 RCQ prep
« Reply #130 on: May 18, 2012, 09:42:44 AM »
I was just reading about 5.3 swap in the jeep
Re: 571 RCQ prep
« Reply #131 on: May 18, 2012, 10:17:14 PM »
Melted oil pressure line to gage prerunning, allfixef up.
571 RCQ prep
« Reply #132 on: May 19, 2012, 12:48:41 AM »
808 has a HEMI 5.7 from a Magnum :)
Re: 571 RCQ prep
« Reply #133 on: May 20, 2012, 11:07:11 PM »
power washed 571 and started tear down tonight.
found broken rear axle vent
loose high pressure line on steering pump
bent/tweaked banjo bolts copper washers on passenger side front caliper
empty front brake circuit
all upper chassis link bushings shot
front shaft yoke hits exhaust on full bump and took out an 02 sensor
both diff covers loose bolts and leaking
broken head light
Re: 571 RCQ prep
« Reply #134 on: May 21, 2012, 09:06:05 AM »
Congrats on your race with the new power plant.    Maybe we should all it "Timex"
