Author Topic: 571 RCQ prep  (Read 70319 times)
571 RCQ prep
« on: April 30, 2012, 12:20:59 PM »
fix motor / replace
Complete RCRCOS race2
profender 2.5's
standard race  prep on wall
move harness mounts back
much
much
much
more
571 RCQ prep
« Reply #1 on: April 30, 2012, 07:16:44 PM »
Motor?
Re: 571 RCQ prep
« Reply #2 on: April 30, 2012, 08:44:15 PM »
it has a real cool sound to it now
Re: 571 RCQ prep
« Reply #3 on: April 30, 2012, 11:31:34 PM »
found that i put the stage 8 lock nut on backwards and my wheel was close to falling off.  only noticed the bias mud line in the shop ridding dirty on one side of the lugs.
removed and re assembled tonight.
remembered shocks need machine work and didnt get anything eyed up to much.
Re: 571 RCQ prep
« Reply #4 on: May 01, 2012, 08:04:33 PM »
i had one of my old school tech guys at work stop over and listen to my motor.  he says bottom end is good, but i have a blown wrist pin and the piston is slapping a valve.  only cause where its in a certain rpm band.  rienforcements are coming tomorrow for a second ear.
bottom line he said run it for the next RCROCS race, but he wouldnt run it for an 800$ race....
Re: 571 RCQ prep
« Reply #5 on: May 01, 2012, 08:57:18 PM »
This thing is just as much of a pos as that red toyota!!!!!!!z
571 RCQ prep
« Reply #6 on: May 01, 2012, 09:07:16 PM »
I would say get it in before rc rocs and make sure the bugs are worked out  before $800 race
Re: 571 RCQ prep
« Reply #7 on: May 01, 2012, 10:41:07 PM »
That sorta makes sense
Re: 571 RCQ prep
« Reply #8 on: May 01, 2012, 11:03:39 PM »
options in the werx
Re: 571 RCQ prep
« Reply #9 on: May 02, 2012, 12:38:56 PM »
motor guy #2 stopping over,  he aready says hed bet me a new motor there is a piston skirt laying in the pan.  he has a bunch of good power options also on hand ready to go  :)
Re: 571 RCQ prep
« Reply #10 on: May 02, 2012, 12:50:28 PM »
haha..
Re: 571 RCQ prep
« Reply #11 on: May 02, 2012, 01:40:29 PM »
Lets do this....
Re: 571 RCQ prep
« Reply #12 on: May 02, 2012, 03:54:07 PM »
told you they were gonna say pull the pan :)
what's up at M4 tonight? I have a wedge to drop off, a full set of fuel lines to install, and rear driveshaft ujoints to change out. All of which I can do there or home.... but I have a handy spare tire in the bed to test fit on the rear of your truck.
Probably free after 7:30 or so.
« Last Edit: May 02, 2012, 03:56:42 PM by mr.mindless »
Re: 571 RCQ prep
« Reply #13 on: May 02, 2012, 05:17:34 PM »
zero point in pulling the pan in car.
if i can get a motor lined up ill swap it this weekend.
Re: 571 RCQ prep
« Reply #14 on: May 02, 2012, 06:46:29 PM »
motor is puzzling guru guy number two.  he has an 9 sec nova, with plates    :o
he his thinking piston skirt, main bearing, or cracked flex plate.
is so confused how dam well the motor runs and sounds.
