Author Topic: LS droid  (Read 77484 times)
Re: LS droid
« Reply #15 on: September 25, 2020, 01:53:37 PM »
Re: LS droid
« Reply #16 on: October 01, 2020, 08:44:46 AM »
able to pull a PCM file with PCMHAMMER last night.
cant find an xdf for 12591721_12589161 but looks like the one i had for the last van was close enough and let me in.  will try to flash it later.
Re: LS droid
« Reply #17 on: February 21, 2021, 06:08:59 PM »
seems like i need to spend 3 hours re learning and re istalling and re googling things to get this to work- kinda annoying since process is fairly simple.
meh
Re: LS droid
« Reply #18 on: July 23, 2023, 07:20:51 PM »
took way to long to find and modify a 6.0/4l60/65 tune for escalades/denali blue/green PCMs so uploading here also.
Re: LS droid
« Reply #19 on: April 25, 2024, 07:21:49 PM »
finally did enough forum digging and figured out my issues with my desktop and lap top.  added missing plug in files and now all good on both systems to edit and flash.
also set up the plasma laptop now for LS PCMs
tuner pro RT
PCM hammer
red/blue    12212156 PCMs
blue green 12587603 PCMs
Re: LS droid
« Reply #20 on: April 25, 2024, 08:56:07 PM »
This is my go to Bin file.
Re: LS droid
« Reply #21 on: April 25, 2024, 09:02:36 PM »
And this is a cool transmission tool.
« Last Edit: April 25, 2024, 09:21:34 PM by gif »
Re: LS droid
« Reply #22 on: April 25, 2024, 09:26:40 PM »
TunerPro Video I grabbed from a seminar.   Its 2.5 hours long.  Lots of good stuff.  Not sure if im supposed to have a copy of this so I put it on my Youtube as a private link.  :-X    https://youtu.be/plMBNXIE10Q
Re: LS droid
« Reply #23 on: April 25, 2024, 09:35:22 PM »
nice.  i def need to do some house keeping and organize my tune library
Caseys J truck comming out soon for some transmission adjustments.
Re: LS droid
« Reply #24 on: December 05, 2024, 09:05:12 PM »
used universal patcher for the first time
its like tuner pro but doesnt care about having a DXF for whatever OS you start with.
used PCM hammer to read bin, use universal patcher for modifications of VATS delete and axle ratio / tire size changes, saved new bin, load it back with PCM hammer.
will see if all is well tomorrow.  then read what nucesence codes show up, repeat process again turning off desired codes.
