Author Topic: Fixer UPer  (Read 69014 times)
Re: Fixer UPer
« Reply #45 on: June 13, 2020, 09:38:28 PM »
This carb layout would need to fill the carb and intake mani.
It’s not leaking, but I can’t find the top for this funnel so slosh is a big issue.
Re: Fixer UPer
« Reply #46 on: June 13, 2020, 09:43:46 PM »
slosh lol
points for shut of funnel!     nice
Re: Fixer UPer
« Reply #47 on: June 13, 2020, 09:45:00 PM »
maybe steering gets easier when there is 2k on the forks?
weird
Re: Fixer UPer
« Reply #48 on: June 13, 2020, 10:02:25 PM »
is there room to add hydraulic steering?
Re: Fixer UPer
« Reply #49 on: June 13, 2020, 10:06:13 PM »
throw a paper rag or paper towel on it before your zip tie.  pre filter and slosh control
or rip a cooland or wiper tank off of one of your piles
Re: Fixer UPer
« Reply #50 on: June 13, 2020, 10:17:19 PM »
It’ll get a coolant something once I find a clean one.
There’s a screen in the bottom of the funnel so that’s good for crap. I’m almost out of gasoline and I’ve got to drive real gently.
Steering better with the vastly reduced slop.
I’d have to do a bit of fab work to put a different steering box in it l, but it will probably eventually get an Astro box. I think swing is right.
First pallet load stored upstairs.
Gonna cut a door pass through before I do the second. Eventually move that vent stack. Bathroom roof feels as solid as office ceiling where the storage is.
Re: Fixer UPer
« Reply #51 on: June 13, 2020, 10:38:19 PM »
nice!  hows it do outside on the grave?  pick up the mill yet?   i should be done with your trailer this week and can return cars before the weekend
Re: Fixer UPer
« Reply #52 on: June 13, 2020, 10:56:38 PM »
On the gravel It spills a lot of fuel from the open bowl.
Rear tires have probably 2” travel, center pivot. It’s good to go!
Front tires are foamed. Tears are tubed and I put them to 50psi. Had been 30/36. Steering tolerable.
Couple more pallets, then the mill.
Re: Fixer UPer
« Reply #53 on: June 14, 2020, 12:07:08 AM »
This is a whole lot different than the forktruck work I’ve done before! Never overhead, or at least not often.
Re: Fixer UPer
« Reply #54 on: June 14, 2020, 12:32:01 AM »
Couldn’t get the bench through the lift by a good foot. But did get the trailer empty.
More shuffling to do and needs of racking but this is noice.
Re: Fixer UPer
« Reply #55 on: June 14, 2020, 08:55:35 AM »
winning!
Re: Fixer UPer
« Reply #56 on: June 14, 2020, 01:12:21 PM »
sorry could have sworn i posted last night i have a metal boat tank from brett if you want it.  looked to be in good shape
Re: Fixer UPer
« Reply #57 on: June 14, 2020, 03:15:19 PM »
Funnel slosh is really slowing me down
Helps to build skill driving smooth though.
Went across the front yard without issue.
Making good progress on all things in general.
Re: Fixer UPer
« Reply #58 on: June 14, 2020, 03:36:16 PM »
wow across your lawn im impressed now!
Re: Fixer UPer
« Reply #59 on: June 14, 2020, 05:01:47 PM »
Impressed at stupidity or capability? I’d go with both.
Back and forth. Gus took compressor and fork took furniture.
