Author Topic: Fixer UPer  (Read 68930 times)
Re: Fixer UPer
« Reply #135 on: February 21, 2025, 09:58:52 PM »
Carried 2 pallets of wood pellets to the house garage from back of the shop. Running like a champ. Might take a couple degrees timing out for easier starting. Sure is running well though.
Don’t have a pallet jack yet, successfully rolled them across the front of the garage to their proper places on 4 2” steel fence posts. Worked a charm. Didn’t blow through the bottom of the pallets as I feared.
Lift could not pick up double stack for 4,000# approx. didn’t stall, just lifted rear tires probably as high as I’d want to.
Ha. Almost the same run, difference being these were on the back of the ram since I bought them Tuesday morning.
And I do have a pallet jack now. Could use one each for shop and garage, but that’d be a waste.
Re: Fixer UPer
« Reply #136 on: April 20, 2025, 01:22:58 PM »
Lowest maintenance unit in the fleet. Really owe to an oil change.
Coolant leaks a bit and still doesn’t charge it’s own battery. but fired right up and moved the dead-battery mower around to unbury it from the back of the shop yesterday no sweat
Re: Fixer UPer
« Reply #137 on: April 20, 2025, 08:41:33 PM »
noice!
i think ill finally give my bucket van an oil change this year.  it has the same oil in it from when i bought it.  i think it needs 3 new to it tires also after the hate i gave them while flat and stuck with burnouts in snow to move it mid winter when the ZJ sold.
