Author Topic: new house for mikemike  (Read 226027 times)
Re: new house for mikemike
« Reply #270 on: July 17, 2020, 10:22:21 AM »
Between rain a week ago instead of completely parched, and adding gutter flow to the pond, a 1.4” storm raised the pond 3.5” instead of 2.25 on a 2” storm.
Pretty wild.
Have not done any math on gallons per inch of pond or per inch of rain over the roofs. Will care when it comes to watering, which is soft planned for next year.
« Reply #271 on: July 17, 2020, 09:54:34 PM »
Whats that little tractor on the truck bed?
« Reply #272 on: July 17, 2020, 11:36:18 PM »
Adjusted my problematic garage door and made it worse. Reverses every 2’ on the way down now instead of once, 4’ from closed, occasionally.
How did I make it so much worse?
Tightened a seriously sagging chain
Removed twist from carriage track due to poor mounting at door header
Centered door chain sprocket on motor final drive shaft
Greased tracks
The grease is probably the problem. Trolly has wooden guides and carriage tracks were bone dry. I figured that was a problem not a desired state.
Damnit.
Oh, and the drive belt looks like this and the model and part number give me 2 auction lot results and that’s it, so I need to just measure the belt and go to TSC
« Reply #273 on: July 17, 2020, 11:38:49 PM »
Sarah’s dad has like 15 wheel horse tractors in various disrepair and parts status and one that he actually uses. That is a nicely restored(ish) wheelhorse as a gift/ prank for him. It’s been threatened for years that he wouldn’t notice another red tractor in the yard so next time we go up that way, it’ll be tested.
« Reply #274 on: July 18, 2020, 11:11:08 AM »
Plow truckin:
‘95 Cummins 2500, with 7.5’ Fischer plow. Needs trans. Body appears okayish? Price dropped 3500 to 2500
If I had a trans laying around that would be very interesting but I don’t.
Would be a candidate to sell high miler for but boy do I like that truck.
Maybe I need to look closer at 4x4 swapping it and not adding another truck. Idk.
« Reply #275 on: July 18, 2020, 12:54:43 PM »
Trans seems easier than front axle & tcase
« Reply #276 on: July 18, 2020, 01:53:04 PM »
2:1 low in high miler would be SUCH a huge upgrade though.
But then counting on some mildly claptrapness and unknown milage and history 45 year old NP205... though with what I put the doubler in the Dakota through, and what we put the racecars through, I don't think it'd be something that would ever leave me stranded even dealing with manual trans + diesel torque
« Reply #277 on: July 18, 2020, 04:20:03 PM »
all 3 post above silly.  stop.
« Reply #278 on: July 18, 2020, 05:53:03 PM »
Find that mythical $300 Jeep for me
« Reply #279 on: July 19, 2020, 12:10:19 AM »
Price keeps creeping up so I started looking at tractors.
What a rabbit hole. And so costly.
I hope the $800 Canandaigua broken-frame Chevy gets back to me and it’s cobbleable
« Reply #280 on: July 19, 2020, 01:07:24 PM »
Rotten Chevy acquired. $500. Needs more of the two critical fluids.
« Reply #281 on: July 19, 2020, 03:41:06 PM »
Driver torsion key nut ripped through the crossmember. Right front frame cracked near plow mount/ sway bar mount. Rotted through the bottom of the frame there where the bottom kicks up from bumper mounting and shit will sit.
Need to decide whether to LOOK for more frame issues or just fix known and ignore the rest. Probably makes the difference between a 2yr and 5yr truck. I might hit it with the needle scaler quick and see what’s obvious and patch it. Worth a couple hours effort AFTER drivetrain leaks are sorted
Cab has had body work. Poorly done.
Put a quart or two in the trans and it was still slow to engage. Think I saw a motor oil leak. Had good pressure after adding two quarts. Power steering was dry, seemed to have power steering after adding fluid but return line leaking badly.
Didn’t beat the rain home so I’ll look at it later.
Batter was nearly flat when I got there. Shows 10v after jumping and running and now restarting on its own a few times. Low compression garbage is awesome to start on a weak battery!
Good aggressive drives. Steers have tread.
Manual tcase shifts properly. Column trans shifter sucks and is out of adjustment, as they all do.
« Last Edit: July 19, 2020, 04:54:07 PM by mr.mindless »
« Reply #282 on: July 20, 2020, 12:51:03 AM »
Running on generator. Don’t know why.
No neighbors out.
I have my own transformer at the street.
Steady 2.6v ac coming to main breaker from meter. Meter not moving at all. No brown or bright or blinks, just sudden out like a trip about 2hr ago.  Just finished getting fridge and freezer and the sump that runs frequently powered up.
Really need to get battery backup on that sump.
I think I’ve lost gas cans. Seems like they used to be coming out my ears, now I’ve got 2 ea 6 gal for gas and Diesel and that’s it aside from small things.
I guess I never kept diesel before.
Getting gas now in case it’s still out in the morning. I don’t remember run time on the ole predator 3500
« Reply #283 on: July 20, 2020, 06:45:10 AM »
Do you know of the Liberty brand pump backup  that runs on muni water? That’s the one I have. No batteries to deal with. Was $200 I think at VP Supply
« Last Edit: July 20, 2020, 09:39:46 AM by KingtheZJ »
« Reply #284 on: July 20, 2020, 09:34:49 AM »
Do you know of the Liberty brand pump backup  that runs on muni water? That’s the one I have. No batteries to deal with. Was $200 I think and VP Supply
Good info, thx Spencer!
