Author Topic: new house for mikemike  (Read 226163 times)
Re: new house for mikemike
« Reply #330 on: August 18, 2020, 11:07:08 PM »
As expected, drilling the mower blades SUCKED.
my drill press is high speed wood shit and that material case hardened if it got hot at all.
Did three of six. welded on the deck a bit. Mounting tube cracked (repeat or previous repair) and under deck blade guide bent and cracked.
Mowed my front yard in drizzle at 10pm:
Country living achievement unlocked.
Cut looks amazing in the dark. 3x the cutting length, twice the lift. Did have to grind 2 blade ends that would kiss (1/16” longer than spec)
« Reply #331 on: August 19, 2020, 02:14:56 AM »
Looks awesome.  Thats razor tight tolerances if 1/16" longer than spec is causing that.    I was impressed how they improved my mowing performance when I did mine.
« Reply #332 on: August 19, 2020, 09:33:21 AM »
Excellent!!!
How does the lawn look like with sun out this morning?
Did it roll coal or more easier now?
« Reply #333 on: August 19, 2020, 10:07:38 AM »
Quote
That is SOP for one of my neighbors
« Reply #334 on: August 19, 2020, 10:16:12 AM »
I'm sure it was loading as it should and blowing some smoke in the hard parts. didn't actually _bog_ anywhere running full speed, and it absolutely would have before if not nearly stalled.
there's some very visible grass where it was tallest but it's less clumped and more spread. it was WET to the point I was having traction issues from clumping on the drive tires, and I probably cut 9" grass to 4.5" in that area.
Cheaper than turboing. Not sure if easier due to difficulty of drilling the blades 😂
« Reply #335 on: August 19, 2020, 10:35:44 AM »
didnt someone say put blades on this thing day one  ::)
« Reply #336 on: August 19, 2020, 03:13:15 PM »
someone said sharpen, not upgrade. what I pulled off weren't murdered, but Look at the length of cutting blade between these and stock. between that and the lift... yup.
« Reply #337 on: August 19, 2020, 03:26:19 PM »
Your old blades looked like they were nearly new.
« Reply #338 on: August 19, 2020, 03:29:04 PM »
the comparison photo was with a literally new spare blade. I got 2 complete sets of used with spindle fittings (one mounted one spare) plus one spare naked blade.
« Reply #339 on: August 19, 2020, 08:46:55 PM »
This racking was an adventure. Highly customized by previous owners haha
Shelves all welded together with legs bolted.
Only had to cut a couple bolts. Chad and seller helped tear down. Thanks for the lead
Should be easy reassembly with forklift, the legs are real light. Hopefully the size and shape work out somewhere good.
Will trim off some hack tot dumbness from the bottoms. Legs are about 10’
Two 8’ bays with 3 shelves each I think.
« Reply #340 on: August 20, 2020, 08:20:14 AM »
cool, glad it wasn't too bad.  get any grates/decking?
« Reply #341 on: August 20, 2020, 08:37:10 AM »
Welded spreaders on all shelves, and 1/2” particle board for about half of it.
« Reply #342 on: August 22, 2020, 06:22:06 PM »
$1200. Some assembly required. BIG bitch. Also big dumb load.
Free iron block 5.3/4l60/tcase too. No pcm or harness. And 350ish gallons of oil in 2 totes. And a tire hookup and oil heat knowledge.
(6) 8r19.5 available asking $300. 10 year old Goodyear’s. I may grab for trailer at reduced price.
I can maybe believe to pulled the trigger on this. I need an engine stand.
« Reply #343 on: August 22, 2020, 07:03:30 PM »
that's a snow moving machine
« Reply #344 on: August 22, 2020, 08:50:06 PM »
You crazy son of a gun
