Author Topic: Cub Cadet 7265  (Read 47830 times)
Re: Cub Cadet 7265
« Reply #45 on: April 05, 2021, 09:07:22 PM »
pulled stuff and measured stuff.
140$ order at surplus to change all 8 hoses on loader and convert to easy JIC hoses instead of custom hoses with mis matched ends.
great.
1hour in to google and still no clear sign of any fluid compatible with cub 737-3025 fluid.
ill do a full 6 gallon change if i can get a substitute, but i guess if im just topping off with the spend cub fluid it will get a couple new quarts only.
Re: Cub Cadet 7265
« Reply #46 on: April 09, 2021, 11:14:31 PM »
cant find any info on the net thats helpful for fluid.
really dont like 17$ a quart with a 6 gallon system   :(
Re: Cub Cadet 7265
« Reply #47 on: April 10, 2021, 05:18:13 PM »
found it online for $115 a 5 gallon so 2 of those on the way.
figured out PN are different for quart, gallon, 5 gallon- that was throwing me
Re: Cub Cadet 7265
« Reply #48 on: April 10, 2021, 05:22:29 PM »
Much better!
I have a little fear of fluid prices when it comes time to put the backhoe together.
Re: Cub Cadet 7265
« Reply #49 on: April 10, 2021, 05:27:48 PM »
that you can probably throw universal tractor fluid in thats like 35$ for a 5 Gallon at TSC
cubs i guess are just picky and nothing really well documented.  i paid 90$ for two filters also on the way, bah.
but i figure i only ran about 10 gals of diesel through this thing, so it should be good for a while with all new fluids and filters and new hoses on the loader.
500$ for 5+ years of service meh
Re: Cub Cadet 7265
« Reply #50 on: April 11, 2021, 11:41:27 AM »
Could be much worse!
Re: Cub Cadet 7265
« Reply #51 on: April 12, 2021, 01:21:09 PM »
changed 8 hydro hoses, all worked as planned.
just on the add line on hydro stick so ill run it a bit and then when fluid and filters come in next week do that full 6gal change.
Re: Cub Cadet 7265
« Reply #52 on: April 20, 2021, 01:08:34 PM »
money taken on my card 4/10
no update other than initial order confirmation.
send request for status last night
got update:  expected to ship 4/25
WTF?
and people wonder why amazon has won.
Re: Cub Cadet 7265
« Reply #53 on: May 01, 2021, 04:34:55 PM »
hydro and filters changed-  took 5 gallons so thats nice i have enough to do it again next time and didnt need to crack into a 2nd 120$ bucket
MFD gear oil changed
bush hawged out back after mowing today.
Re: Cub Cadet 7265
« Reply #54 on: July 07, 2021, 12:44:03 PM »
decided to tear apart the gear box in my brush hog today, found very near failure output roller bearing and no out put seal.  oil just was dumping out as fast as you put it in since i have owned it.  looks like someone at one point packed it with heavy grease so thats probably what has saved it.  not sure it would be functional for much more.
managed to find numbers on bearings and measure seals needed.  40$ to amazon here Friday yay.
Re: Cub Cadet 7265
« Reply #55 on: July 09, 2021, 05:16:47 PM »
brush hog back together with new bearings and seals and holding gear old, win.
Re: Cub Cadet 7265
« Reply #56 on: August 05, 2021, 05:11:25 PM »
solid 2 hours of bush hoging on Nicks John street property today.
this thing is full service duty ready!
Re: Cub Cadet 7265
« Reply #57 on: May 10, 2023, 05:38:16 PM »
grease job
added 2 quarts engine oil   :o
blew out air filter and radiator
hydro fluid still looks brand new from service when i got it and did it.
this thing only gets about 10 gallons of diesel run though it a season so its fine
has 2 or 4 seized grease fittings that i should deal with in loader.
Re: Cub Cadet 7265
« Reply #58 on: March 02, 2024, 05:15:16 PM »
bah, found a thorn in front tire today that decided to be flat and leaky.  odd time of year for that to show it self.
