Author Topic: 440 3 phase  (Read 6874 times)
Re: 440 3 phase
« Reply #15 on: March 06, 2020, 10:23:46 PM »
tom and I used the new band saw to cut out some 1/2" plates for his Lincoln locker.  the band saw power feed hawgs!  thing is awesome!
Re: 440 3 phase
« Reply #16 on: April 01, 2020, 10:34:03 PM »
boo for letting the magic smoke out of my rotary phase converter control box tonight.
meh
Re: 440 3 phase
« Reply #17 on: April 01, 2020, 11:15:55 PM »
How’d that happen? Rewiring mistake?
Re: 440 3 phase
« Reply #18 on: April 01, 2020, 11:22:02 PM »
has worked with no issues for me since installed.  Jeff was over tonight turning new links for buggy.  only thing i can think was the longest sustained use so far.
let the smoke out of one the the big capacitors inside the unit.  i ordered another, hoping for easy fix.
Re: 440 3 phase
« Reply #19 on: April 02, 2020, 08:46:00 AM »
Weird. Hope not a regular occurrence
Re: 440 3 phase
« Reply #20 on: April 02, 2020, 09:18:08 AM »
jeff said i should measure current through each of the legs and make sure they are not more than 5-10% off max.  if so you can change the capacitor to try and balance it or something- id have to research but i have a good clamp on meter to check easy.
if the 12$ can doesn't fix it, i wouldn't be opposed to getting a 7.5 or 10hp unit.  When my 4hp drill press is in low gear the start up current pisses the phase converter off and one of the contactors clicks a lot till it gets going lol
