Author Topic: new house for mike  (Read 158059 times)
Re: new house for mike
« Reply #120 on: May 28, 2019, 10:20:25 PM »
my hf generator has sat for 10months plus, cant even remember last use.
2 pulls puts like new.  10 minutes of idle, electric start charged up enough to work.
« Reply #121 on: May 29, 2019, 07:55:21 AM »
couple RFQ's put out for 4500 ft^2 of spray foam
ooof cant wait to see that shock
« Reply #122 on: May 29, 2019, 09:36:55 AM »
Iirc I think the going rate is a buck a sq ft at one inch so I'd guess 9k labor/material
« Reply #123 on: May 29, 2019, 10:07:40 AM »
So about $1/lb  :P
« Reply #124 on: May 29, 2019, 10:56:53 AM »
i was hoping for a quote under 12K with 2" on the walls and 3" on the ceiling.
« Reply #125 on: May 29, 2019, 09:44:55 PM »
thanks for all the help guys, that went much better than expected and was great.
pallet racking nocked down and loaded by 4:45
all unloaded at new place by 5:30
10 pairs of hands or so made it super quick and easy!
racking in great shape, lift is awesome.  got some good pallets and some sweet roll around shelve carts!  nice!
« Reply #126 on: May 30, 2019, 06:26:57 PM »
shop keys returned today!
apartment keys to be returned saturday!
« Reply #127 on: June 01, 2019, 06:52:49 PM »
apartment keys returned!
just need to call next week to confirm RGE is off and im DONE.
100 lbs of sand and 10 gallons of alum oxi poly to seal up the shop side floor.   time for tables and lifts.  picked up another van chassis for stock this morning.  lets do this!
« Reply #128 on: June 01, 2019, 10:38:55 PM »
(3) 4x8 shop tables built tonight.
« Reply #129 on: June 02, 2019, 10:37:15 PM »
slept in a bit today, nice breakfast :)
truck load of garbage to dumpster.
wegmans, lowes, liquor store run while i was in Henrietta
visit from JJ and Girl
electric service install started tonight.  shop panel mounted and plan formed.  100a and 60 a breakers installed in lower shop panel.  All materials on hand to get after it tomorrow.
Italian hot sausage on the grill
1 gallon of round up applied around property
mowed
Visit from Nick and Raina
3 loads laundry.
formed a plan for new bathroom plumbing while folding laundry.  i guess i need to amazon some stuff for that haha
that's Sunday.
« Reply #130 on: June 04, 2019, 11:11:58 PM »
ran conduit and pulled wire.  connected to 100amp breaker in barn "main" panel that is fed from meter.
didnt die.
so i have a sub panel that now has a ground that goes to no where other than the pannel shell.  does it need a ground rod?!?  wtf
« Reply #131 on: June 04, 2019, 11:14:24 PM »
neutral and ground is bonded in 150 amp main panel.  the sub i ran is 100amp and 4 wires.  hot hot neutral ground.  even though the ground and neutral are hooked to basically the same bar 2" apart in the main which i dont get what is the point but ill ignore that for now.
at my sub box, neutral is comon with main box neutral but ground goes no where..... other than the pannel.  (pvc conduit and wood mounted)
« Reply #132 on: June 05, 2019, 09:56:45 AM »
False, it goes to the ground of the panel that im feeding from to share ground.... so there would be no point to run a 4th wire if i added a ground rod for the sub...
lots of bad info and its amazing how many people think they know things lol.
JJ says i am good with no rod, going with that
« Reply #133 on: June 05, 2019, 10:05:01 AM »
google says
Quote
Grounding for Sub Panels
A second panel or sub panel should have the neutral and ground terminals or bars isolated from each other, this is why the main circuit feed to the sub panel must have 4 wires, with a dedicated insulated wire for the neutral and a separate wire for the ground.
All the ground wires bond back at the main panel together with the neutrals.
The sub panel neutral bar or terminal should not be bonded to the enclosure or the ground of the sub panel. The sub panel ground should not have a ground rod tied to it.
The bonding for the main ground sources such as a ground rod is made at the main panel where all the grounds are bonded together as well.
« Reply #134 on: June 05, 2019, 10:05:48 AM »
I am slightly confused with the question here, but I think you have it right.  The neutral to ground bond and ground rod will be at your main panel only.  Sub panel will get its ground from the ground bus and neutral from the neutral bus of the main panel.
