Author Topic: new house for mike  (Read 158022 times)
Re: new house for mike
« Reply #105 on: May 23, 2019, 09:56:45 AM »
Yes, 2-2-2-4 quadruplex AL URD is rated for 155A when direct buried.  Rating of wire depends on the insulation, configuration, routing, etc...
weird, could not find anything with rating when buried.  but the buried part will just be the 60amp feeder.  the 100amp feed will just be in the barn (about a 50' run.
« Reply #106 on: May 23, 2019, 10:02:05 AM »
You need a main or maximum 6-handles per code.  The 6-handle rule may not even apply to residential I'd have to look it up.
Checked with the boss yesterday and learned something new. Turns out that each of those circuits at the top of the panel are "main disconnects" but there should only be a maximum of 6 double pole breakers and no single pole. The spaces below are meant for individual 110v circuits. I guess it used to be a thing...
« Reply #107 on: May 23, 2019, 07:58:57 PM »
100% moved out and cleaned out both rentals.  ready to turn back keys and collect securities.
ugh!  relief!
« Reply #108 on: May 24, 2019, 08:15:31 AM »
excellent!
« Reply #109 on: May 25, 2019, 05:04:24 PM »
2nd wireless router fail, why does it connect with problems.  stupid!  this should be simple plug and play.
read through all these bs settings and just will not connect fully.  lame.
ready to just send back my cable modem and everything, just use my phone.  will stream 3 devices with zero issues.
« Reply #110 on: May 25, 2019, 07:17:50 PM »
clicked "cloan MAC address" as suggested in help section, all good.
so stupid
« Reply #111 on: May 25, 2019, 11:43:05 PM »
In that case: fuck your provider.
Who is it? Gotta be spectrum right? Been an age since I had to give a care about consumer internet service. Yuck.
Glad it’s fixed. That would have taken me a goodly while.
« Reply #112 on: May 26, 2019, 12:49:18 PM »
shingle repairs made to pantry roof!  replacement sump pump ordered!
those were the only 2 must do's on the house, time to build the shop :)
« Reply #113 on: May 26, 2019, 03:42:39 PM »
its hot out, decided to gut my pantry today and start working on first floor full bath!
« Reply #114 on: May 27, 2019, 08:09:40 PM »
driving the mower to the corner gas station to fill, much better than stupid epa gas jugs!
« Reply #115 on: May 27, 2019, 08:43:54 PM »
Non-ethanol?
« Reply #116 on: May 27, 2019, 10:33:46 PM »
its 2019, everything made since like 1990 is 100% ethanol rated.
keep smoking the E0 train though!
« Reply #117 on: May 28, 2019, 07:57:09 AM »
Everything that has the potential to sit for long periods gets E0. Don’t care about daily drivers. Not worried about seals and such but more fuel separation.
« Reply #118 on: May 28, 2019, 08:33:53 AM »
Ditto.
I only put e0 in my fuel cans when I’m home. I do abuse that on the road though. I have plenty of things that probably don’t love E. If I could drive equipment with a >2 gal tank to fill though, I’d forget about it!
« Reply #119 on: May 28, 2019, 09:12:11 AM »
room TV hung
new sump pump installed
pantry crawl space cover removed and inspected
front porch stairs and railing post replaced / rebuilt
3 courses of shingles removed and replaced / top cap replaced pantry roof
Pantry cabinets and trim gutted to walls
lawn mowed
shop table lumber unloaded
2 loads of debris to dumpster
