Author Topic: 1958 Chevy Apache  (Read 87578 times)
Re: 1958 Chevy Apache
« Reply #75 on: April 16, 2019, 02:36:56 PM »
Radiator finally arrived.
Had to rework the aluminum mounting bracket to suck the radiator up tight to the core support.
« Last Edit: March 02, 2020, 01:55:50 PM by gif »
« Reply #76 on: April 16, 2019, 02:38:44 PM »
Was there a clearance issue?
« Reply #77 on: April 16, 2019, 03:29:21 PM »
yes,
fan and shroud into the engine.
also moved the engine and tranny back 3/4"
« Reply #78 on: April 16, 2019, 03:51:31 PM »
the truck im doing now, is the first one i had to raise the radiator 2" to clear steering box, and put the fan in front of the radiator.
also FYI if you dont like that oil fill cap extension, the cap also directly works on the valve cover once the extension is removed.
« Reply #79 on: April 16, 2019, 06:42:15 PM »
good to know..
« Reply #80 on: April 17, 2019, 08:12:28 AM »
this thing looks way cooler in person!  love it!
« Reply #81 on: April 30, 2019, 10:38:12 PM »
started burning steel tonight.  3 hours in so far
« Last Edit: March 02, 2020, 02:00:03 PM by gif »
« Reply #82 on: May 06, 2019, 04:03:12 PM »
thats purdy
« Reply #83 on: May 06, 2019, 05:37:16 PM »
« Last Edit: March 02, 2020, 02:03:08 PM by gif »
« Reply #84 on: May 27, 2019, 12:22:53 PM »
Engine clean up complete. 3 cans of degreaser and 2 hours of pressure washer.    New intake and oil pan gaskets.  waiting on new hardware for flexplate and torque converter final assembly.
« Last Edit: March 02, 2020, 02:07:19 PM by gif »
« Reply #85 on: June 13, 2019, 09:08:59 PM »
Engine and tranny bolted back together and back in the frame.  Started on the plumbing.  Fuel lines, brake lines.
« Last Edit: March 02, 2020, 02:08:03 PM by gif »
« Reply #86 on: June 14, 2019, 11:25:08 AM »
you have to use a special tool to flare your fuel lines or just a standard double flare tool?
« Reply #87 on: June 14, 2019, 02:03:00 PM »
standard tool.    however i only use nicopp line now.
https://www.youtube.com/watch?v=9V9Jg1BORlk
« Last Edit: June 14, 2019, 02:09:07 PM by gif »
« Reply #88 on: December 03, 2019, 01:12:01 PM »
Gif, we need an update!!!
« Reply #89 on: December 24, 2019, 09:38:17 AM »
I last touched this thing in June.  left off with the plumbing mocked up.
Waiting for after the holidays to dig back into this.
Next steps are the E brake and column shift.
Followed by engine/PCM and electrical.
I plan to have it on the road this summer...
