Author Topic: JEEPWERX CJ7 Buggy Style  (Read 75211 times)
Re: JEEPWERX CJ7 Buggy Style
« Reply #345 on: August 19, 2015, 11:26:36 PM »
this is how i would set it up
rear: 6" shaft showing, 8" shaft compressed, 1" of coil preload= total rate of 57lbs/in      ~ 14" 100/ 16" 150  =60lbs/in
Front 7" shaft showing, 9" shaft compressed, 1" of coil preload= total rate of 55lbs/in     ~ 16" 100/ 18" 125  =55.5 lbs/in
« Last Edit: August 20, 2015, 08:38:47 AM by M4wdFab »
« Reply #346 on: August 19, 2015, 11:31:07 PM »
i like running 50/50 shaft showing for racing, so with 2-3" of preload you could get there if you wanted over wreck wheeling status.
another trick, you can actually fit 18/18 on a 16" shock or 16/16 on a 14" shock, but since you have different shocks all your coils can be the same anyway.
« Reply #347 on: August 20, 2015, 12:10:18 AM »
Can you fit a 18" and 16" on a 14" shock?  Seems tight.
« Reply #348 on: August 20, 2015, 06:41:53 AM »
are your air shocks now 14" and 16"  or?
Air shocks are currently 16" front and rear.
I bought 14" coil overs. But was worried up front it would severly limit my travel in the rocks, so I also have a pair of 16".
I'll most likely run the 14" front and rear.
And sell the 16".
« Reply #349 on: August 20, 2015, 08:39:06 AM »
oopps cut and paste error, fixed
« Reply #350 on: August 20, 2015, 08:40:58 AM »
oh, so you have 6 shocks... ok ill rerun the numbers.. i would get all 16" springs then
« Reply #351 on: August 20, 2015, 08:42:42 AM »
Why re run numbers?
I was gonna run 14" front and rear.
« Reply #352 on: August 20, 2015, 08:55:11 AM »
i ran numbers for 14" and 16"   going to 14/14 in the front will need more rate with less spring to compress at ride
« Reply #353 on: August 20, 2015, 10:30:32 AM »
Ok
What does this mean?
14" shock in front
16" in rear?
« Reply #354 on: August 20, 2015, 10:50:37 AM »
i should just stop over and show you how to run the numbers sometime.  your situation is real easy with knowing air shock pressure on a 1 3/8" shaft
i think we are getting confused with what shocks where
if you had 16" on it for wreck wheel shaft showing (60/40ish), going to 14"'s with Race shaft showing (50/50) should work out great, and keep all your coils at 16"s to allow swapping around if you need.
« Reply #355 on: August 20, 2015, 11:01:25 AM »
K maybe tomorrow after j&j?
« Reply #356 on: August 20, 2015, 11:13:33 AM »
i wish it was friday!   but ya after J/J i can stop over
« Reply #357 on: August 20, 2015, 12:04:20 PM »
This might help.
« Reply #358 on: August 20, 2015, 12:05:58 PM »
ill check that math after lunch haha
« Reply #359 on: August 20, 2015, 12:27:47 PM »
I have 125/125 on the front of my Yj. 14" saw coilovers. I will take a pic I have about 4"-5" shaft showing. 1" preload.
