Author Topic: JEEPWERX CJ7 Buggy Style  (Read 75338 times)
Re: JEEPWERX CJ7 Buggy Style
« Reply #120 on: July 09, 2014, 01:54:47 PM »
these were the switches i ended up with
http://www.summitracing.com/parts/pco-5513pt
« Reply #121 on: July 09, 2014, 02:26:10 PM »
Cool thanks mike
Found them on amazon also
20 amps
275 +12 shipping for pack of 25
Don't need 25 and Summit shipping is awesomeness
Circles are way easier to cut then rectangles.
« Reply #122 on: July 09, 2014, 02:50:55 PM »
i need one that's 3 position with center off for my radiator control, not so important cause it switches ground to a relay pack.
« Reply #123 on: July 09, 2014, 02:54:42 PM »
Yea thanks for reminding me.
I heard you switch fan speeds over the weekend and I had wanted to do the same.
And same one for winch control
Momentary switch for starter also.
I'm gonna continue with what I have now and replace as needed.
Can LIFETIME supply any waterproof rockers?
« Reply #124 on: July 09, 2014, 02:57:27 PM »
I just have the same style you got before.
I could order waterproof in 100 qty from my switch people, It would be cheaper than $14 each....
« Reply #126 on: July 09, 2014, 03:09:51 PM »
I get my rectangle-hole Contura switches from Waytek. I keep some in stock. None momentary, idk if they are available. They do have on off on.
« Reply #127 on: July 09, 2014, 03:13:29 PM »
We have the contoura style, have dpdt, and also momentary spdt for winch. Also some snap together "panels" for the switches.
« Reply #128 on: July 09, 2014, 03:23:37 PM »
Should I be concerned or should I just click ok as usual?
Lol
« Reply #129 on: July 09, 2014, 03:26:55 PM »
I dunno  but its a link to that
Cole Hersee Waterproof 25A PVC-Coated Momentary On General Usage Toggle Switch for LED and HID Light
« Reply #130 on: July 09, 2014, 03:30:03 PM »
I assume these babies are not in Farmington?
« Reply #131 on: July 09, 2014, 04:29:53 PM »
I'd have to look.  On way to b-low
« Reply #132 on: July 14, 2014, 10:06:54 PM »
« Reply #133 on: July 14, 2014, 10:51:00 PM »
What's the general consensus on guage of battery cables and winch power cables?
0 or 1 ga?
I'm looking at about:
 6 ft batteries to master switch
8-9 ft winch to batteries
Anyone use welding cable?
« Reply #134 on: July 14, 2014, 11:28:27 PM »
Welding cable is usually more expensive. 2ga is probably plenty, it's what most winches come with. Are you planning to run your winch through your master? What is it rated for?
