Author Topic: The Profender 4-seater  (Read 132201 times)
Re: The Profender 4-seater
« Reply #15 on: January 08, 2012, 09:20:35 PM »
this buggy is coming along great, cant wait to see it wheel!
« Reply #16 on: January 10, 2012, 12:03:21 PM »
Picked up the filter/regulator from NuWay in Farmington yesterday. Ordered some AN fittings for it today from Summit.
The little things will bleed you dry. Looks like I will be running with 4.10s and stock shafts for a little while. At least for winter testing,and maybe race 1.
« Reply #17 on: January 10, 2012, 12:26:25 PM »
meh.  It's only money... :P
« Reply #18 on: January 10, 2012, 12:37:40 PM »
Sure, Mr RCV shafts.  ::)
« Reply #19 on: January 10, 2012, 01:22:57 PM »
Its from Summit, came all wired and has long leads for starter and a 8ga for the power supply, I like it a lot. Nice switches as well.
http://www.summitracing.com/parts/QCR-50-163/?rtype=10
That's a nice panel.  Only thing that'd make it nicer is breakers instead of fuses.
« Reply #20 on: January 10, 2012, 01:27:50 PM »
All the neighbor hood chicks have got to be digging this hog
Liz_rn
« Reply #21 on: January 10, 2012, 02:53:57 PM »
You they are all knocking down the door to see it  :D
« Reply #22 on: January 12, 2012, 08:45:10 PM »
Had to throw some chicks out of the garage.
Got it running again, the fuel pump sounds much happier.
« Reply #23 on: January 15, 2012, 03:03:51 PM »
Took the knuckles off, things look very bad in there.
If we had tapatalk I would post pics.
« Reply #24 on: January 15, 2012, 03:06:47 PM »
Drivers side lower king pin
Passenger side lower king pin bearing
« Reply #25 on: January 15, 2012, 04:07:43 PM »
EWWWW
« Reply #26 on: January 15, 2012, 04:51:13 PM »
Better than 571's.
« Reply #27 on: January 17, 2012, 08:11:02 PM »
New lower race and bearings installed. Got them next day thanks to Nu-Way
Upper kingpins and seals I had to order. Coming from Northern Driveline.
« Reply #28 on: January 17, 2012, 09:11:16 PM »
those had at least two or three laps left on em!
« Reply #29 on: January 18, 2012, 01:54:50 PM »
Im tired of spending money on this. Bah.
