Author Topic: project: 1949 FlatShopRat  (Read 49623 times)
Re: project: 1949 FlatShopRat
« Reply #150 on: June 15, 2017, 11:59:34 PM »
drove home for first work commute duty!  ha
plates and stickers mounted
« Reply #151 on: June 16, 2017, 08:38:16 AM »
successfull commute in.
thing is pretty much a rocket ship haha.  love it.
need to wire wheel the roof to eliminate the rust droppings
« Reply #152 on: June 16, 2017, 09:22:00 AM »
baller!
« Reply #153 on: June 16, 2017, 10:18:57 AM »
unbelievable you cobbled this together so quickly...
really awesome life for a junk van
« Reply #154 on: June 16, 2017, 11:50:31 AM »
should come check it out.
still has a small trans leak- i am fearful something is cracked on the housing, or it just has a torn seal around the NSS selector switch output.
« Reply #155 on: June 16, 2017, 02:40:46 PM »
Throw a potion in it....
I think it was a rebuilt trans no?
« Reply #156 on: June 16, 2017, 11:15:53 PM »
trans had written on the top 5/15/16 on it
« Reply #157 on: June 16, 2017, 11:16:49 PM »
ill try to investigate first.  it shifts really nice and pulls hard.  i think its just a leak or seal but its a pretty good drip.
im into it a pan gasket and filter so far.  pretty easy to get to on the lift.
« Reply #158 on: June 16, 2017, 11:22:06 PM »
decided i cant find what i want so building what i want.
48' of 2x5"
72' of 2x3"
24' of 2x4"
11 gage picked up today
stopped at lowes and grabed some treated 4x4s and 2x4s
got the base wood work done tonight.  should have the bed done mocked up if not done ready for planks tomorrow
« Reply #159 on: June 17, 2017, 09:25:49 AM »
Watching this closely....
There is an FC that would look sweet with a stake bed  ::)
« Reply #160 on: June 17, 2017, 09:43:14 AM »
Me too.
'48 needs something...
« Reply #161 on: June 17, 2017, 11:33:01 PM »
better pay attention or you might miss it!
« Reply #162 on: June 17, 2017, 11:37:35 PM »
im in 600$ in materials and 16hrs labor so far on the flatbed FYI
« Reply #163 on: June 18, 2017, 12:29:48 PM »
There is a sawmill near me if you want rough cut. Green Mountain Lumber they are good to work with we have gotten a bunch of stuff from them
« Reply #164 on: June 18, 2017, 10:16:48 PM »
ok thanks ill give them a call.  JJ has a buddy that has some on hand also to try.  May talk to Erik to see if he has any leads closer.
got two door latches changed tonight and the new flat bed bolted down to the chassis.
horn wires repaired and horn mounted.
trying to decided if the horns are 6v or 12 volt   :o
