Author Topic: Troys new Truggy Chassis  (Read 96351 times)
Re: Troys new Truggy Chassis
« Reply #105 on: June 04, 2013, 04:58:19 PM »
I have beat that shat out of my airtex racing- it works.
i do like the ends on that carter pump.
that said, if there durability is anything like the carter diesel lift pumps, id ignore them as an option.
« Reply #106 on: June 04, 2013, 08:17:31 PM »
I am using airtex in my 3rd buggy, no problems with any of them, Plus they are available at any parts store.
« Reply #107 on: June 06, 2013, 11:02:52 PM »
idk not quite there always boils down to cost for me
rear disc brakes done\
what and where should i be doing to make some driveshafts
« Reply #108 on: June 06, 2013, 11:55:33 PM »
all 1350's and nothing less
get some yokes / shafts from yard and hack them together unbalanced rather than balenced smaller shat.
« Reply #109 on: June 07, 2013, 10:31:19 AM »
hack it together like smike said. Hell, run square shit. You're not racing. And if you change your mind on that you can put some good shat together and you'll have spares that were cheap.
« Reply #110 on: June 08, 2013, 01:44:51 PM »
I still run a square shaft in the front of the J truck.   All 1350 joints.     Never had a failure.   And if you saw the beat down I put on it last weekend....  :o
« Reply #111 on: June 09, 2013, 10:13:56 PM »
i still have the square shafts from the mj ,have to redo one end from 1310 to 1350.i guess my real ? though is if im looking for a splined front what vehicle should i look for with 1350's at both ends?
parts ordered,engine will run by end of week or at least i hope with this engine
« Reply #112 on: June 10, 2013, 09:48:54 AM »
newer 3/4 and 1t front stuff (usually CV at one end), most rear fullsize stuff.
« Reply #113 on: June 12, 2013, 09:00:33 AM »
I'm gonna try and hit the jy this weekend and try to find some yikes.
I ordered some 3/8ths aluminum fuel line,do you need a special flare tool for that or can you use a brake line flare tool?
« Reply #114 on: June 12, 2013, 09:14:48 AM »
Good luck flaring Al without cracking it.
I'm ignorant - maybe it's easier than I expect.
« Reply #115 on: June 12, 2013, 09:24:28 AM »
thats what I would think as well...
i would think you would need to anneal it first...
« Reply #116 on: June 12, 2013, 09:27:21 AM »
SMike and I were thinking of hitting J&J on Saturday. Is that where you were going to go?
« Reply #117 on: June 12, 2013, 09:35:05 AM »
Cmon can't be that bad,all the cool kids do it right.but at only 14 psi you think just a couple hose clamps would be fine?
I went to j&j last week during the rain storm,no shafts laying around they scrap them.was thinking of wilberts new place all those vehicles are on stands and nice gravel open till 4 on sat
« Reply #118 on: June 12, 2013, 10:02:56 AM »
Hmmm
« Reply #119 on: June 12, 2013, 10:04:22 AM »
How do you like your non load reaction orbital? I'm thinking of buying the same for mine.
