Author Topic: 1978 F250 The new Shop shovel!  (Read 49063 times)
Re: 1978 F250 The new Shop shovel!
« Reply #60 on: December 30, 2012, 09:43:27 AM »
my sweet light and wipers fixed them self- heat works too.
gota get the radio back next.  its been a while since that last fixed its self.
« Reply #61 on: December 30, 2012, 09:44:04 AM »
i love this truck....
can i get some snow pics... ill trade for sun ;)
« Reply #62 on: December 30, 2012, 09:45:52 AM »
this mornings work
« Reply #63 on: December 30, 2012, 09:46:30 AM »
i finally shoveled off my deck, id say i had a good 18"
« Reply #64 on: January 08, 2013, 09:33:58 AM »
« Reply #65 on: February 09, 2013, 10:47:00 PM »
did work after a new fuel filter and a time out 1/2 way though!
« Reply #66 on: April 05, 2013, 08:49:29 AM »
well, failed with a marine boat tank.. pickup tube must be stuck or something dumb.  tank strapped to bumper and hose put in tank.
she kicked and spat and faught for a while.  even tried to pull losing a wire to the coil!
we exceeded the duty of the winch trying to lift the XJ shell on to the wedge.  i guess it has a slipper clutch in it to keep you from breaking shat.
an optima, a vice grip, a fuel filter, gas tank, and some lube we were back in service picking things up and putting things down.
awl4928
« Reply #67 on: April 05, 2013, 09:19:47 AM »
I would be surprised if it had a clutch in the winch and if it did load would be way higher than the xj shell on a wrecker boom winch.   Likely the free spool/not assembly contraption is not locked in fully or is extremely worn.  I have thought I was locked in fully when I wasn't even on new trucks.  When I couldn't get a civic stuck in park moved I knew something was wrong
« Reply #68 on: April 05, 2013, 11:31:43 AM »
i dont know something was clearly slipping but not breaking  i did not want to stick my head near it
« Reply #69 on: April 05, 2013, 12:10:02 PM »
sounds wise!
« Reply #70 on: April 09, 2013, 11:36:45 AM »
« Reply #71 on: April 09, 2013, 12:42:40 PM »
haha cool.
i think my cable is good for now. thanks
« Reply #72 on: February 15, 2014, 06:48:01 PM »
plowed last 3 times with 5% clutch.  exhaust blew apart a while back.  got a wicked 4hour head ache last time.
Got mad enough and put this guy on the lift carefully.  extended clutch linkage rod and actually fixed clutch issues.  re welded up exhaust after finding a flex exhaust that failed.  mint
100% duty and much nicer to plow with.
« Last Edit: February 15, 2014, 06:49:58 PM by M4wdFab »
« Reply #73 on: February 19, 2014, 10:26:40 AM »
« Reply #74 on: March 07, 2014, 04:51:37 PM »
