Author Topic: MMTR Mini  (Read 121420 times)
Re: MMTR Mini
« Reply #225 on: July 28, 2019, 09:00:32 PM »
Lots of garage .org today. More tomorrow. Excited to start on this.
Lots of bites on Beetle parts. Surprising.
I think I need to get my engine hoist back from Troy.
I think I may sketch out quick ramps In Joe for easy double loading before I start. SO NICE to not have the buggy in the garage.
Re: MMTR Mini
« Reply #226 on: November 18, 2019, 08:36:06 PM »
I shoulda renewed reg on this in October. Inspection is up now and I can’t renew. Damnit.
This state is a pain in the ass.
Re: MMTR Mini
« Reply #227 on: January 31, 2021, 05:30:21 PM »
Trans stuck in reverse today. Was parked outside. Hope it’s frozen, will know after it sits in the garage for a day.
Re: MMTR Mini
« Reply #228 on: February 13, 2021, 06:43:35 PM »
Fixt
Now that I’ve done it once, trans could be out and in in an hour, probably. It’s 20” long and as big around as a coffee can. Weighs maybe 30#?
Could probably also do this repair in the truck.
I think there’s nearly no lube left in the trans. I didn’t try to seal those case halves again. Will see if the drip per day gets much worse.
Re: MMTR Mini
« Reply #229 on: March 01, 2021, 09:44:44 PM »
Beetle is pending pickup. Yanking engine tomorrow on a day off. Emptied the last of moving out of it just now.
Hopefully put some of its better parts into the wagon (hoping brakes and axles, both of which are upgrades to a tdi, and the wagon has a clicking CV which is what precipitated this.
Beetle body is going on a Chevy powered Toyota frame. Guy built one and sold it, wants another. Maybe some of y’all who go to mud events will see it.
Seems perfect to get rid of everything I don’t want at once.
MMTR Mini
« Reply #230 on: March 03, 2021, 11:52:42 PM »
Beetles are way more complex.
90% ready to send the shell. Need a bit more wiring out of the car and that’s about it.
ECU and cross body harness are in the cowl same as any mk4, but it’s all under the dash behind the windshield. Still a wet location.  Bet those two mouse nests were great places. No wiring damage in there. But headlights were poorly rewired sometime.
« Last Edit: March 04, 2021, 12:00:09 AM by mr.mindless »
Re: MMTR Mini
« Reply #231 on: April 28, 2021, 11:28:39 PM »
Found out from Ken at the meeting tonight that the guy I bought this Beetle from died in a private plane crash in Michigan last year. Shame, he was a really cool guy. Very much one of us.
Re: MMTR Mini
« Reply #233 on: February 27, 2024, 05:43:23 PM »
fuel tank leak. looks good+clean from the outside, but there's some spooge around the low point and tank drain, as though there is a patch in that area that's leaking.
Noted a puddle in the gravel underneath the back end of it. at least it sprung the leak outside on the gravel and not while parked inside.
Re: MMTR Mini
« Reply #234 on: March 05, 2024, 05:55:51 PM »
Wiped it off and got more leak. Sump rotten from the inside.
Only right fix is probably to drop tank and cut the bottom of the sump out. Every leak is surrounded By a soft spot. Structural clean paint :(
Re: MMTR Mini
« Reply #235 on: March 05, 2024, 06:12:02 PM »
boo! hiss!
i have half a can of POR tank sealer if that would help you.  its probably still good.
Re: MMTR Mini
« Reply #236 on: March 05, 2024, 08:21:29 PM »
that stuff looks perfect. I need to clean and seal the MG's tank too, half a can is probably right for either one of those but probably should just pick some up. I think this is about a 7 gallon tank, Midget probably 7-10. I don't know if that one is a leaker but it's rusty inside and needs a good clean and seal
Re: MMTR Mini
« Reply #237 on: March 05, 2024, 08:23:55 PM »
I will certainly regret it if anything hits and holes the bottom of that tank though. maybe repair and then coat. that whole half square foot section certainly has no structure left to it...
Re: MMTR Mini
« Reply #238 on: March 05, 2024, 08:30:08 PM »
what shape (geometrically) is the tank?
maybe just easier to plop in a replacent thats close or just make one.
the tank i made for ians TJ5 was actually pretty easy.
Re: MMTR Mini
« Reply #239 on: May 14, 2024, 01:22:39 PM »
Decided to order Eastwood fuel tank sealer for both this and for the MG, since its tank is all rusty inside and needs the exact same work done.
Hopefully at least get Gus taken care of next week so I can get down trees chopped up sometime before they rot.
https://www.eastwood.com/gas-tank-sealer-kits-eastwood-gas-tank-sealer.html
Half the price of the POR-15 kit. Hopefully serviceable – will report back, naturally.
