Author Topic: The 48' black box  (Read 82601 times)
Re: The 48' black box
« Reply #150 on: June 02, 2017, 12:14:22 PM »
I should add that to my enclosed.
« Reply #151 on: June 02, 2017, 12:20:28 PM »
insured with comp and collision now.
just curious, from where?
« Reply #152 on: June 02, 2017, 12:24:55 PM »
State Farm writes mine. lowboy is overcovered agreed value $10k for like $100/yr. That's from back when it really was worth 5-7. I guess I should make it worth that again soon.
« Reply #153 on: June 02, 2017, 01:28:39 PM »
state farm
90$ / 6 months
« Reply #155 on: June 05, 2017, 09:12:02 AM »
i think i have that exact tank from ebay, 42 gallons.
get the nice RV fill and vent too for external fill
« Reply #156 on: July 11, 2017, 10:55:13 AM »
Mike dropped of a 225 for me- i noticed its an F at 36XX lbs.  my Gs are all 39XX lbs rating.
looked at my last scale ticket and it was 21050 on the trailer pad     :o
i am thinking i should stick to Gs lol
« Reply #157 on: July 11, 2017, 11:13:00 AM »
I don't know what's on my trailer, but all my loose tires were LR F
« Reply #158 on: July 11, 2017, 02:27:53 PM »
What's the situation with water fill ports for these things? I am seeing city fill ports and gravity fill ports. Some with vents, some with check valves.
I just want garden hose thread into the tank and I am thinking there needs to be some kind of vent for both filling and using water. Not sure if I would ever really need a check valve.
« Reply #160 on: July 11, 2017, 02:41:31 PM »
no garden hose thread just jam it in to fill.  i found one that had the same 1.25" fill and got clear hose in between tank and fill
« Reply #161 on: July 11, 2017, 02:45:44 PM »
Does water come out of the vent when it's full with that setup then?
« Reply #162 on: July 11, 2017, 03:01:10 PM »
ya, there is a 1/2" hose that i have hooked to the vent port and the top of of the tank.  my tank had 4 nipples.  top fill, top vent, bottom pump flood, bottom drain.
« Reply #163 on: July 11, 2017, 04:03:12 PM »
things with check valves AND threaded connections are for "city water hookups" that go on the pressure side of the pump, they're for when you have full hookup and can just use the hose pressure to run your system and ignore the pump and your tank.
« Reply #164 on: July 11, 2017, 04:56:05 PM »
That makes a lot of sense. Thanks
