Author Topic: 2000 jetta TDi  (Read 31897 times)
Re: 2000 jetta TDi
« Reply #75 on: January 14, 2015, 12:59:01 PM »
im gona go with no on that one haha
i guess a cold hole or two would agree with the banging and thumping on 2-3 cylinders for a few seconds after starts  this week haha
Re: 2000 jetta TDi
« Reply #76 on: January 14, 2015, 01:34:35 PM »
Ether worked on the old backhoe every time. If the battery was up to it...
Re: 2000 jetta TDi
« Reply #77 on: January 14, 2015, 03:59:56 PM »
Skip the technical stuff and spray some ether in the air cleaner.
Don't you dare do that with operational glowplugs OR grid heaters!!
2000 jetta TDi
« Reply #78 on: January 14, 2015, 04:13:08 PM »
OK, fine. Don't blow it up. Or start it on fire...
I guess the ole backhoe was glo-plug inop.
You know my motto...
Re: 2000 jetta TDi
« Reply #79 on: January 14, 2015, 06:04:37 PM »
choke cable is frozen on the mowzer. ether got it going!
I really hate having to park that outside :*(
Re: 2000 jetta TDi
« Reply #80 on: January 14, 2015, 07:38:36 PM »
Not to hijack the thread....mike, we always sprayed the hell out of our choke cable on the 140. If it's the same wound spring style cover as ours, they love a good soaking of wd40 or whichever is your favorite stuff. Bent it one winter from freezing up and learned our lesson.
Re: 2000 jetta TDi
« Reply #81 on: January 14, 2015, 09:36:33 PM »
Castle makes a white lithium grease with a red straw deal...
Use that in all cables and linkages... Works nice on seat slides
Re: 2000 jetta TDi
« Reply #82 on: January 15, 2015, 12:29:32 AM »
this guy kicked and spit and started though, relocated to shop lot to think about what it has done.
Re: 2000 jetta TDi
« Reply #83 on: February 27, 2015, 08:58:43 PM »
god this thing is really pushing into the negative investment.  i think one of my worst choices.  bah
Got it on the lift tonight, found one vacated driver lower ball joint bolt, and the other two were loose.  fixed, and test drove.  stopped for fuel and rear left locked and smoking.
changed out Caliper.  delco copper washers supplied wrong size by a lot but get it on and bled.
no pulls or drags and all seems good.  gona put 200 miles on it tomorrow.
meh
Re: 2000 jetta TDi
« Reply #84 on: February 27, 2015, 09:21:18 PM »
Since the dippy craped out on me I was looking at these sweet rides.
Re: 2000 jetta TDi
« Reply #85 on: February 27, 2015, 10:10:19 PM »
What happened to the Diplomat?!
Re: 2000 jetta TDi
« Reply #86 on: February 28, 2015, 12:28:07 AM »
they just want stupid money for them even to 200K
they are sweet little cars- just seem bitchy to get the bugs out that come with high miles.
Re: 2000 jetta TDi
« Reply #87 on: February 28, 2015, 01:05:09 AM »
Something went in the transmission on the diplomat.
I was finding them pretty common between $2000-$2500 but high milage.  Right now I have just been running the truck I will probably pick one up this spring
Re: 2000 jetta TDi
« Reply #88 on: February 28, 2015, 03:49:15 AM »
Seems like a ways to go before that's true...
Re: 2000 jetta TDi
« Reply #89 on: February 28, 2015, 07:33:13 AM »
if not for Arie parts id be in $4500 and 30hrs of labor, for a 3K jetta....
thing is WAY paste poor investment
