Author Topic: brolite cherry pop 573  (Read 84015 times)
Re: brolite cherry pop 573
« Reply #120 on: May 06, 2015, 12:58:07 AM »
contrary to popular belief this thing will do a full standing 2 wheel smokey burn out with 4.10's and locked 35's     8)
« Reply #121 on: May 06, 2015, 08:05:20 AM »
Impressive.
« Reply #122 on: May 06, 2015, 08:39:47 AM »
And then take off like a turtle all the way to 35mph before grabbing 2nd ;)
« Reply #123 on: May 11, 2015, 10:59:33 PM »
fuel system 100% done and functional
tank and old lines removed
new pump and lines run.
Hit list on the wall
started eying up front and rear shock mounts.
list is way shorter than a buggy build! love it.
« Reply #124 on: May 12, 2015, 11:53:57 PM »
rear shocks in
« Reply #125 on: May 13, 2015, 07:53:37 AM »
Nice
« Reply #126 on: May 13, 2015, 11:07:57 AM »
rear shocks in
Looks awesome. Just curious why you decided on that location for the reservoirs?  I can see it getting damaged if another truck lands on you or you get in a rollover.   I am not second guessing you, just want to learn.   Would the red circle in the attached pic be a better location to protect the reservoirs?
 (I know nothing about reservoirs, no idea if angles have to matter here)
« Reply #127 on: May 13, 2015, 12:35:46 PM »
Angles don’t matter. Air flow is good.
« Reply #128 on: May 13, 2015, 01:27:34 PM »
i guess i hadn't really thought of a truck landing on me haha
ill be honest they just kinda got clamped there because the fox factory series letters were right side up haha
i had them flipped down when just the stud was welded on, but then they got flipped up after the outside bracker got made
« Reply #129 on: May 13, 2015, 01:28:37 PM »
could flip them under the tube
« Reply #130 on: May 14, 2015, 01:00:28 AM »
front shocks in
« Reply #131 on: May 14, 2015, 09:22:47 AM »
I think I heard that TJ springs are gonna be the hot ticket in the front of these to get a little more rate if needed. Not sure what you've got in there for your extra height.
« Reply #132 on: May 14, 2015, 09:24:01 AM »
ZJ v8 front coils..
« Reply #133 on: May 14, 2015, 09:47:28 AM »
leaving ranger coils as is for now.  a lot of weight is removed from the truck, that should be good for at least an inch of ride.
changing coils is a massive amount of work, probably require hardware / control arm / trailing arm replacement lol
« Reply #134 on: May 14, 2015, 10:05:48 AM »
i remember trying tj springs...
didn't work so well...
