Author Topic: Tow Ratings  (Read 201882 times)
Re: Tow Ratings
« Reply #135 on: August 26, 2021, 12:53:03 PM »
Quote
CDL requirements become more confusing when the vehicle is towing a trailer.
There are three key aspects to consider when assessing CDL operator requirements for commercial work trucks involved in towing a trailer: truck GVWR, trailer GVWR and GCWR of the truck-trailer combination. Trailer GVWR is most critical to determining when a CDL is required.
When a trailer has a GVWR of 10,001 pounds or more and the combined GCWR of the truck and trailer is 26,001 pounds or more, a CDL is required by the operator. For example, if a trailer has a GVWR of 11,500 pounds and is towed by a truck with a GVWR of 15,000 pounds, resulting in a GCWR of 26,500 pounds, then the operator must have a CDL.
In contrast, when the trailer in the truck-trailer combination has a GVWR of 10,000 pounds or less, requirements allow for a greater GCWR for both the truck and trailer without requiring a CDL. For example, a truck with a GVWR of 26,000 pounds or less can tow a trailer with a GVWR of 10,000 pounds or less and not require the operator to have a CDL under federal requirements. However, CDL requirements mandate that the truck and trailer GVW not exceed 26,000 pounds and 10,000 pounds, respectively. In short, the truck and trailer cannot be overloaded.
see bold
https://www.ntea.com/NTEA/Member_benefits/Industry_leading_news/NTEANewsarticles/The_role_of_GVWR_and_GCWR_in_specifying_work_trucks1.aspx
