Author Topic: Brandy new 4500 Cummins  (Read 251024 times)
Re: Brandy new 4500 Cummins
« Reply #465 on: January 21, 2018, 08:00:35 PM »
something in the front was loose at 30K, tires have steers have been wearing funny for 20K.  I flipped them about 10K ago.  the truck has 53K on it.  i dont like to do things twice.
« Reply #466 on: February 13, 2018, 04:02:53 PM »
rolled over 60k
needs a bunch of regular maintenance before next use.  All parts and fluids on the shelf ready for a sunny day(s).  one of Nates guys is interested in looking at the truck.
« Reply #467 on: March 22, 2018, 10:48:37 PM »
oil change and filter
under hood fuel filter
chassis fuel filter / separator
codes cleared.
broken marker light fixed
DEF filled
60,989 miles.
« Reply #468 on: April 22, 2018, 06:53:18 PM »
unloaded down to VA friday night was painful.  violent shaking from 50-62MPH.  has had some goofy tire wear 40-60K miles and i had been planning to run the steers out another 10K before fixing front end looseness.  rid home loaded much better but after inspection today the front steers are whooped.  confirmed upper ball joint play both sides onlything loose.
changed upper balljoints in about 10 minutes a side.  i think i spent more time looking for something to use as a 60mm socket and a 33m wrench than actually doing it.  had to cut down a 1 3/16 socket to fit but was easy after that.  steers pulled and loaded in ZJ to drop at Lewis tomorrow morning to mount new rubber.
Front end lubed
637XX miles
front brakes like still 80%
« Reply #469 on: April 22, 2018, 11:06:56 PM »
crazy balljoints are dead well before brakes.
« Reply #470 on: June 11, 2018, 07:42:21 AM »
got a cash offer on this unit minus flatbed and tuner.  need to find out what its really worth i guess.  could be a good time to bail before it gets into out of warranty work.
2014 Ram 4500 6 speed manual 4x4 60 CA
« Reply #471 on: June 12, 2018, 08:38:03 PM »
any body interested in a flat bed or tuner  ::)
« Reply #472 on: June 12, 2018, 08:50:17 PM »
hang on to the flatbed till you decide what the next truck is? might need it. or it might sell for what it cost you and who cares.
« Reply #473 on: June 12, 2018, 10:55:14 PM »
probably worth 1200.  too shitty to put on a new truck and too heavy to put on a chopped down box truck toter project.... believe me i have ideas....
« Reply #474 on: July 24, 2018, 01:23:26 PM »
same guy back again.  I have been asked to take to his shop to plug in and check DPF pressures ect.
a lot of really good trucks on the market right now.
« Reply #475 on: October 15, 2018, 09:26:47 AM »
needs a clutch
F
« Reply #476 on: October 15, 2018, 09:57:13 AM »
https://www.phoenixfriction.com/t-g56-clutch-life-what-to-expect.aspx
reading that i guess im lucky it lasted 65k
Mike what one do you have?  should i go ceramic or organic?  these prices dont seem bad with everything included , clutch, flywheel, hydralics upgrade
« Reply #477 on: October 15, 2018, 10:09:35 AM »
I just remembered this is a 4x4.
That makes it way more annoying.
Also things I just remembered: there's a club member with a lift that can lift this unit.
- lift & remove both driveshafts, break all fasteners free, pull most/all trans to block bolts, remove clutch hydraulics
- lower, remove crossmember, support trans and tcase on my bigass trans jack
- lift truck away from trans, then swap clutch bits
- installation is reverse of removal.
I've done this 2x on the ground and it didn't killed me. it's really not bad at all.
call South Bend, talk with them about your use and future power plans, and they'll probably suggest the same hybrid ceramic/organic I have with upgraded hydraulics.
My invoice from the replacement shows SDD3250-g 2005.5-2009 G56 550-650hp 1200tq
Not sure what changed in 2010, hopefully not a big deal.
« Reply #478 on: November 14, 2018, 09:15:00 AM »
got a service soon light last night.  no other indicators.
google says CCV filter at 67,500 miles.   60$ filter in the valve cover lol
two brake taps and two 0-100% accelerator taps in 10seconds should clear the message apparently.
bah!
« Reply #479 on: November 26, 2018, 06:02:57 PM »
SDD3250-GK   clutch ordered with some cyber Monday discount from Garofalo performance!
