Author Topic: 571  (Read 264801 times)
Re: 571
« Reply #240 on: July 12, 2014, 09:53:11 AM »
Broken asphalt is still better than stones.
Re: 571
« Reply #241 on: July 12, 2014, 01:54:54 PM »
Or pavers...
Re: 571
« Reply #242 on: July 13, 2014, 07:01:38 PM »
Jailbreak:
Was a complete PITD getting those supports cut. Need a 6" cutoff wheel that I can put into the space for a 3"...
Will need to move the tcase back for 700r4. And maneuver it even to get the 350 out. This is all the way in.
Found that the front shaft carrier bearing is loose on the shaft and loose as a bearing, both. Kissed the rear brake hard line with a cutoff wheel when the grinder kicked.
Not happy about moving the tcase and having to change shafts. Rear shaft has almost no slip left. Front shaft has no slip above the carrier bearing. Need to put the trannies next to each other on the floor but I expect to be looking at 4"
Sub strap mounts, inner belt mounts, center console mounting... Boo.
Re: 571
« Reply #243 on: July 13, 2014, 07:34:42 PM »
Fluid smelled crappy, lots of fine metal on the plug. Wtf.
Re: 571
« Reply #244 on: July 13, 2014, 07:49:32 PM »
Can 2"lift come off that slip? Remember it doesnt have to slip...
Re: 571
« Reply #245 on: July 13, 2014, 09:28:18 PM »
TCase doesn't want to move back (or at all) with all 4 bolts out. Trans still in car. About to get angry at it... Breaking for a breather and beverage. I'm not going to bed without two trannies next to each other and A Plan.
A match is a plan, Mark :)
Re: 571
« Reply #246 on: July 13, 2014, 09:42:23 PM »
probably gona need a porta ram to push the skid back down
Re: 571
« Reply #247 on: July 13, 2014, 10:59:47 PM »
Lol, wouldn't dream of it...
Re: 571
« Reply #248 on: July 14, 2014, 01:01:02 AM »
Yup, pushed the skid down and she moved.
About 3.3" longer. need to move trans mount, mount pillow block off the side instead of flat while lengthening front shaft. Need to move case back, I was gonna cheat that tempermanently but it doesn't fit under the tube it's mounted from.
That technical drawing said how far back the mount is. Around an inch. The pan is also an inch longer so I need to move the mount for clearance, not just drill holes further back.  It is also a rectangle, which eats driveshaft and bearing and bearing mount clearance.
It will be easy to go back to a TH350 should I need to - the carrier of a 1350 CV is almost exactly the right length for a mini shaft between trans and case after things are pushed back.
It's gonna be super tight to make this race. I HATE that. Tempted to call it off now just so I don't kill myself this week. I figure at best I have two full days of work and that's assuming I don't need to redo the floor and can just remount what I took out. Oh, wait. Moving the case. Whose mounts stick the rough the floor. Fuck.
Re: 571
« Reply #249 on: July 14, 2014, 01:03:44 AM »
Oh - all so I can blow up a stock 100k tranny that's been on a shelf for a decade - since rushing a rebuild has proven to be a BAD idea.
Re: 571
« Reply #250 on: July 14, 2014, 09:05:49 AM »
measure twice cut once not your style?
Re: 571
« Reply #251 on: July 14, 2014, 09:09:16 AM »
TV cables on a 700r4 are a pitd. Does your motor have a spot for it?
Re: 571
« Reply #252 on: July 14, 2014, 09:44:04 AM »
@re - I need better cutting tools...
@rywan - probably not. things arriving tmw for that, hopefully it has what I need and/or I can rob from the TV cable on the Dakota or carb linkages on the spare eagles.
Re: 571
« Reply #253 on: July 14, 2014, 09:49:27 AM »
that trans is too much longer
wait and have another 350 built, or click buy it now from summit and have one tomorrow.
Re: 571
« Reply #254 on: July 14, 2014, 09:53:10 AM »
changing too many things that have been proven to finish races!
that mid shaft (and front shaft) cluster has been a week point for a while.
