Author Topic: 07 4" lift install  (Read 35377 times)
07 4" lift install
« Reply #30 on: April 21, 2012, 06:46:08 AM »
If its like Jess' jeep you have to buy the whole hub assembly
Re: 07 4" lift install
« Reply #31 on: April 21, 2012, 07:53:42 AM »
i drilled, tapped, and used a bolt, spacer, washer, nut to pull out the snapped off in side part.  took the old broken head and bolted the top back on with some RTV so he could go wheeling today.  Dealer part 3 days away or see if Arie can get it today.
« Reply #32 on: April 21, 2012, 09:22:13 AM »
15$ at Doan for this little sensor, i cant believe so cheap.
ajduell
  • Guest
« Reply #33 on: April 22, 2012, 12:31:30 PM »
Guess I should visit your forum more often...didnt know this was in here. Pretty cool.
